General Diesel Discussion
4.5L V6
Old Apr 25, 2017 | 01:00 AM
sassyrose's Avatar
sassyrose
Has anyone repowered a LCF 4.5L to a 6.0L? I have a 2005 LCF600 with the 4.5 and would like to repower it. I have a doner truck which is a 2005 2x4 F550. Thanks
Old Apr 25, 2017 | 02:13 PM
Ford_Six's Avatar
Ford_Six
A torch and a welder can make anything fit, but the hard part will be getting the electronics to play nice.
You'll probably have to put the whole 6.0 harness in, along with the cluster.
If it is an in-town truck, I'd swap in an Isuzu 4BD1T.
Old Apr 25, 2017 | 02:39 PM
sassyrose's Avatar
sassyrose
4.5L repower to 6.0L In a LCF
Thanks for the reply. I'm familiar with the torch approach was hoping that would not be necessary. The 6.0 should drop in where the 4.5 came out of. I will be adding length which I think I have room to do. I did get a doner 05 f550 single cab. I have the complete electronics to change over. Not sure why you would go with the Isuzu over the 6.0. My end project is a rollback tow truck with power to spare.
Old Apr 25, 2017 | 09:42 PM
Ford_Six's Avatar
Ford_Six
Mostly size constraints and ease of install. The Isuzu setup is fairly standalone, and being a four cylinder it's compact. I have swapped in 6.0s before, and they have about four times more wire than you think they do. Econoline vans are worst to do the swap on.
Old Apr 25, 2017 | 09:58 PM
sassyrose's Avatar
sassyrose
Appreciate the info. You're right about the wires and the electronics. Don't know the specs on the Isuzu. Will do a little research. Do you see any reason other than the electronics that the 6.0 will not fit? Any input on the auto trans 5r110w. I think that's what is in the f550. Thanks
Old Apr 26, 2017 | 10:23 AM
Ford_Six's Avatar
Ford_Six
You will likely need a custom crossmember for the transmission, and to have the driveshaft altered to fit, but that should physically fit. I'm not as sure on the engine itself, but it should be workable.
Old May 22, 2017 | 06:04 PM
Pan'ya Neou's Avatar
Pan'ya Neou
Originally Posted by GloveGuy
Hi Delusion,
Since I last replied to this thread the price is now up to "approximately" $14,000. I've put the job on hold and the shop is waiting for my reply.
I'm simply weighing my options at this point.
Where are you located? I'm sure we're not close geographically as I'm located in Vancouver, Canada.
If I could get the job done for around $7000 I'd invest the money and sell the truck. I just don't have a lot of faith in this engine, as you might imagine.
If I could find a little cummins for this truck I'd probably do that and keep the truck.
Any thoughts and/or suggestions you have would be greatly appreciated.
Hi.. I'm kind to have the same problem as you and I need some direction if you don't mind. I live in Burnaby BC. I just bought the Ford LCF (private).. after a few weeks, found out the anti coolent keeps building pressure. I took it to a shop and they want to open up the engine (could be a gasket or crack engine) could cost up to 13k. Do you have any ideas or suggestions? Thank You
Old May 22, 2017 | 07:03 PM
sassyrose's Avatar
sassyrose
I think I would look for a shop that can do a real scan on your motor and at least a second opinion before a teardown. You might want to visit Dieseltechron on youtube. Some real good information on the Ford diesel engines. He covers the 6.0 powerstroke which is the 4.5 less 2 cylinders pretty much has the same issues.
Old May 25, 2017 | 12:18 AM
Pan'ya Neou
I found out the anti coolent keeps builing up pressure. I took it to a shop and they want to open up the engine (could be a gasket or crack engine) could cost up to 13k. Do you have any ideas or suggestions? Thank You
Edit/Delete Message
Old May 25, 2017 | 09:45 AM
IHateCommieCars's Avatar
IHateCommieCars
Edit/Delete Message
That price is robbery. You can buy a rebuilt engine and pay to have it installed for less than that. And, it's way more likely that it has a blown head gasket rather than a cracked block. You can get head gaskets put in a 6.0 for less than $5000, and this truck is waaayyy easier to work on. I'd love to put headgaskets on one of these engines - what a fun job - it's like the engine is out of the truck on an engine stand.
Find someone to put gaskets on it for $3500 or less.
Old Jan 21, 2020 | 03:04 PM
James Beaudin's Avatar
James Beaudin
Lcf
I have an LCF. With no start
ficim is 48 icp is 800 on crank
ipr is 35% fuel is present
compression according to computer is 29-45 on all cylinders
wont fire
any ideas. Use to them stopped
Old May 29, 2020 | 09:56 PM
Claude Case III's Avatar
Claude Case III
Junk 4.5 with 65000 miles Locked up
I know it’s been a couple years but we bought a truck like that had major issues what did you end up doing with your motor issues ???
Originally Posted by GlovedGuy
Hi Guys,
Question:
If my diesel engine is apart and has been diagnosed, shouldn't the shop where it's in for repair be able to give me a firm quote, from that stage of the job, to completion?
Back Story:
I'm one of the many that am stuck with a Ford LCF with a bad engine. It's a 2007 and I purchased the truck in early 2009 and am the original owner. It currently had 46,000 original miles on it.
A couple of weeks ago, it was driving to a supply yard and it starting bucking pretty badly so we pulled over and stopped immediately.
Upon getting it diagnosed at a local diesel shop they determined that the connecting rod bearing on cylinder one was spun and a new engine was going to be $25,000 Cdn.
I called 2 other shops and they didn't even want to look at it once they found out about what it was.
I reluctantly went to the dealership where I bought the truck and talked to them and they said they thought they could fix it.
Turns out that they can fix it and, as we speak, the engine is out, disassembled and the service manage says they know how much labour costs will be and are 90% sure on the parts. As it stands they "think" it will be $7,000 with parts and labour when they're done but they're asking me to be prepared for up to $9,000, "just to cover our ***." He says that once they get into the assembly of the engine they may require more parts to complete the job.
Does this sound fishy or am I missing something?
Thanks for the time. I look forward to any opinions I can get before proceeding.
Old Aug 6, 2020 | 04:06 PM
  #28
Tedwill99's Avatar
Tedwill99
New to this forum so hopefully this is the place to post my question. I have a 2006 LCF.
It has recently started to lose power on occasion when we are driving it. Sometimes won't start back up.
We usually pull over and let it "rest" for a minute or ten minutes and then it starts and drives fine??
The blower seems to come on a lot more as well.
Wondering if this problem seems familiar to anyone?
Thank you.
Old Aug 7, 2020 | 01:41 PM
  #29
Olds64's Avatar
Olds64
Ted, I suggest you start a new thread in the 6.0l PSD forum (since we don't have a forum for the 4.5l).
https://www.ford-trucks.com/forums/forum107/
The General Diesel Discussion forum is pretty slow and your question might not be noticed buried at the end of an old thread. The 6.0l guys should be able to help. Good luck!
BTW, you could always rip out that 4.5l and swap in an old 6.9l IDI. Heck, you could even get one with a turbo on it and you'd be set to go.
Old Mar 21, 2021 | 04:41 PM
  #30
DonNichols's Avatar
DonNichols
4.5 excessive crankcase pressure
Well I picked up a 2008 LCF With 68,000 miles. Blowing oil out of dipstick holder.. paid $11,000 & drove it 350 miles home. Lost 2 quarts. No smoke from exhaust. Ran 85 mph dropped to 60-65 on long inclines -- turbos would whistle an wind up kick in and back to 85. It beed at mechanic for 2 weeks and he doesn't have an answer for the high crankcase pressure. Any one with advice or had this issue?
NIN
Mar 4, 2019 10:56 PM
Wrace
Feb 17, 2017 05:49 PM
smokeymountainst
6.7L Power Stroke Diesel
54
Jan 10, 2015 01:14 AM
StanleyZ
6.4L Power Stroke Diesel
Jul 15, 2012 03:12 PM
hank89
Jul 13, 2007 08:54 AM
