02 ABS light and bouncing speedometer.
Old May 20, 2015 | 11:00 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Well....
Swapped the VSS for a new one from Ford. In the process broke the clips off the original connector so I picked one up from O'Reilly's and splice it in properly. Changed the gear oil in the rear diff, THAT was way overdue good God. Buttoned it all back up, filled up the diff, took it for a test drive this morning aaaaand - nothing.
ABS light, OD flashing, no speedo, and no cruise. Tried running the harness up to the firewall as suggested earlier and I couldn't find any issues - even the convoluted tubing is still in good shape.
Only other thing I can think of right now is I may have spliced in the new connector backwards, but would that even matter? The new connector wires are both white, no identifying marks, so I hooked the left side up to red and the right side to green (OEM orientation in the original Ford connector).
Old May 20, 2015 | 12:00 PM
Bonanza35's Avatar
Bonanza35
It must be in the wiring or the VVS is bad. That's what happen when mine went out, no speedo, cruise & OD light flashing.,
Old May 20, 2015 | 01:16 PM
Krazee Matt
Veteran: Navy
VSS is brand new Ford-sourced. This only started happening after the flood waters. First the ABS went south, then the speedo started acting up two days later before finally quitting altogether. Wiring looks to be intact, haven't had time to probe terminals and wires fully yet.
Old Jun 21, 2015 | 06:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
mine went out again with the rain every day for the past 2 weeks, then yesterday it started working again after 2 days dry.
this morning it is raining, and it stopped working on the way to the store.
Old Jun 21, 2015 | 11:24 AM
Krazee Matt
Veteran: Navy
I finally fixed mine, had a separate thread in the Excursion forum.
Mine ended up being the ABS module itself. It receives and interprets the VSS signal before sending it to the speedo/odo. Based on where mine was (under the driver battery), I guess it got flooded out and shorted internally.
Old Jun 21, 2015 | 12:53 PM
tjc transport
i ain't rite
did you have to replace the entire ABS unit, or just the electric part?
Old Jun 21, 2015 | 01:42 PM
Krazee Matt
Veteran: Navy
Just the electronic module on the ABS pump.
https://www.ford-trucks.com/forums/1...l#post15444533 <-- should be the follow up post on my fix from the Excursion thread.
Old Jun 22, 2015 | 04:43 AM
jetdoc's Avatar
jetdoc
Originally Posted by aawlberninf350
Rain water dripping to fuse box through leaky windshield seal?
Welcome to my hell.....I had your symptoms and a bouncing tach as well...
Home Depot has nice tarps to cover the cab for when it rains.
Old Nov 30, 2015 | 08:17 PM
Wildfire532FB's Avatar
Wildfire532FB
Originally Posted by tjc transport
i think i found it.
stopped at the body shop this morning. of course this morning the light was out, speedometer worked and OD light was out.
the mechanic suggested bleeding the brakes again, saying there may still be an air bubble in the ABS unit from when i blew the brake lines last fall. put the pressure pot on, and sure enough, got 3 bubbles out of the lines.
brake pedal is a lot firmer now too.
not sure why that would effect the speedometer though.
Did this fix the issue?
Old Dec 1, 2015 | 08:59 AM
tjc transport
i ain't rite
no. one of the headlight modules broke a wire that was hitting the abs module, shorting it out. it finally burned out and i had to replace the module.
Old Dec 1, 2015 | 11:28 AM
Krazee Matt
Veteran: Navy
Wow Tom, so yours was way different than mine shorting from flooding... That's nuts that a broken wire shorted it and caused all kinds of chaos!
Old Dec 1, 2015 | 03:26 PM
tjc transport
i ain't rite
yea, it drove ne nuts for a while. i only found it when i realized the driver side headlight was not working.
when i pulled it apart there was a burn mark on the ABS module from the wire arcing against it.
and that also explained the intermittent work/ no work.
after i fixed it i realized it would only screw up when the headlights were on.
Old Dec 6, 2015 | 07:48 PM
  #28
Wildfire532FB
Mine was acting up, just had a shop look at it and they think it is the module but it stopped doing it the last 2 days they had it and so i took it back and it hasn't done anything since.
tjc transport
May 18, 2015 12:01 PM
ramrod7373
Sep 24, 2012 06:57 AM
fixitman1310
Mar 20, 2011 10:15 AM
squeals99
Apr 17, 2006 08:53 PM
beerman682002
Nov 25, 2004 02:30 PM
