Sponsored by: Real Truck
Check engine, ABS light on
Old Nov 24, 2004 | 09:37 PM
beerman682002's Avatar
beerman682002
Check engine light and ABS light is on and speedometer doesn't work but truck runs fine. Anyone have any ideas!
Old Nov 24, 2004 | 09:47 PM
clydehauler's Avatar
clydehauler
Probably your sensor on the rear axle went. It is for both your ABS and speedo. Cost around $16 at ford dealer and easy to put on.
Old Nov 24, 2004 | 11:12 PM
Hockycop's Avatar
Hockycop
My ABS came on, on an F-150 I had. it was simply a fuse........
Old Nov 25, 2004 | 02:30 PM
Hellrazor1's Avatar
Hellrazor1
Probably the fuse, our one work truck does that, but you cant put it in gear then.
