E4OD Transmission Woes
Old May 9, 2015 | 11:21 AM
4_whl_hvn's Avatar
4_whl_hvn
Red face E4OD Transmission Woes
So here goes. I have a '96 F-250 CCSB 460 4x4 Auto.
Ever since I bought the truck, the trans will go into limp mode with a code 628 and no other codes.
I have been driving the truck around for a while and have made some observations. When I reset the codes, I have noticed it only goes into limp mode when I am in OD going up an incline and give a bit of throttle. When I reset and drive around town or on flat roads, it will not go into limp mode. But the first time I hook up a trailer and go out of town, it goes into limp mode.
I have replaced the filter and done a complete fluid change. When I dropped the trans pan, it was not horribly dirty, just some very minor ferrous dust (from the clutches i presume). I checked all connections, took the dash apart and checked the PSOM board (no problems found).
Am I due for a trans? Is the Shift Solenoid Pack bad? Is the TC bad?
For now I just reset it every time, but it gets annoying. I am just wanting to get a better feel for what I may be in for so I can set aside funds.
Thanks.
Old May 9, 2015 | 11:51 AM
BLK79's Avatar
BLK79
I have fixed two of these E4OD trans behind 460's with nothing more than replacing TPS on throttle body. Symptoms weren't exactly same as yours. Pull codes and see what comes up if anything. Lack of ck engine light DOESN'T mean there aren't any codes stored.
Old May 9, 2015 | 01:17 PM
'89F2urd's Avatar
'89F2urd
good excuse for a zf swap....if it isn't as simple as a tps of course.
Old May 9, 2015 | 01:20 PM
jaagen's Avatar
jaagen
He said he did pull codes and got 628 and no others
Old May 9, 2015 | 01:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No.
No.
Is the TC bad?
Most likely.
Remove the inspection cover from the bellhousing. Look at the forward face of the torque converter. It's probably discolored. That's from heat from it slipping. A new converter will fix this problem.
Old May 10, 2015 | 08:46 AM
4_whl_hvn's Avatar
4_whl_hvn
K, thanks Mark. I will check the TC when I get a chance. If it is discolored, I will change it out. Any suggestions on good TC's?
Old May 10, 2015 | 09:16 AM
GoFastGuy's Avatar
GoFastGuy
I'd go with just a normal replacement from the parts store
whalebus2112
Jan 24, 2014 05:35 PM
davidwags3
Jan 20, 2014 10:22 AM
DesertStorm
15
Nov 1, 2011 10:03 PM
fkaster01
15
Mar 30, 2009 09:23 PM
frank-id
Oct 25, 2008 12:02 AM
