Oil level
Old May 6, 2015 | 06:19 AM
  #31
bizzelj's Avatar
bizzelj
Originally Posted by 87crewdually
That plug is for your EGR solenoid valve that is not there. Someone removed it and put a block off in it's place.
That's what I was thinking but had to double check thank you
Old May 6, 2015 | 07:50 AM
  #32
mohoneywell's Avatar
mohoneywell
theres a possibility that it is a fuel leak, which is picking up oil and grease on the way to the concrete. you should be able to smell fuel though.
I had a wet fuel filter hsng which I fixed with new Banjo Washers, blue spring mod and a billet cap.I know, by replacing multiple parts I dont know which was leaking, but I did them all at once due to access..(Van)
It was the only time I saw any wet spots under this one.
Old May 6, 2015 | 08:57 AM
  #33
bizzelj's Avatar
bizzelj
Could that also make it's way to the bell housing? I have the blue spring mod already I will check again on the leak
Old May 6, 2015 | 11:12 AM
  #34
mohoneywell
Do you smell fuel? it will be prominent. I could smell it when I walked around the front of the van.
yes, it will make its way back down the valley.
there are also multiple spots for an oil leak to develop in the valley. oil cooler cover gaskets, oil filter assy gaskets, oil filter cover, Turbo supply line, HPOP cover,etc....
Old May 6, 2015 | 11:25 AM
  #35
bizzelj's Avatar
bizzelj
I smell normal diesel exhaust I think I'm going to check that banjo this later. There is a sensor or something behind the oil filter and it looks a little wet I'm thinking that could be it as well
Old May 6, 2015 | 09:46 PM
  #36
bizzelj's Avatar
bizzelj
I try and smell the drops on the bell housing but it doesn't smell like anything
Old May 8, 2015 | 10:28 PM
  #37
bizzelj's Avatar
bizzelj
Well I've been chasing this oil leak for over a weak since I've noticed it was low on oil and it hasn't lost any oil
SJMaye
2015 - 2020 F150
Oct 2, 2018 09:31 PM
thaefele
6.4L Power Stroke Diesel
Jan 3, 2009 11:06 PM
stevestroke01
Aug 11, 2008 05:18 PM
BryceGS
Jul 28, 2003 01:58 AM
