Romping=oil level???
Old Jul 15, 2003 | 01:54 AM
BryceGS's Avatar
BryceGS
Hi Guys,
Changed my oil the other day for the first time and much to my dismay I discovered what "romping" was at startup. I checked my oil level and discovered it a bit too high. I took about a quart of oil out and the romping has subsided quite a bit. The oil level is still towards the upper full mark so I will take more out till I hit the middle of the dipstick. I only put about 14 3/4 quarts of delo in, so it surprised me that the oil level was too high. There must be some hidden pockets of oil hidden in that monster.
Cheers,
Bryce
First-time Diesel owner
Old Jul 15, 2003 | 10:26 AM
The Diesel Dude's Avatar
The Diesel Dude
If the romping continues to be a problem, get some anti-foam additive from the International dealer and add to the oil to see if it helps.
Old Jul 16, 2003 | 07:15 PM
Debug's Avatar
Debug
Joe, what oil would you recommend?
Old Jul 17, 2003 | 01:14 AM
The Diesel Dude
I'd use Shell Rotella but the reason I suggested you try some anti-foam agent is because you seemed to say it got better when you drained out some oil. That could indicate a foaming or aeration problem which will drive your high pressure oil system nuts. It is worth a try just to see if there is anything to be gained.
Old Jul 27, 2003 | 09:37 PM
SavageSam's Avatar
SavageSam
A couple of questions, 1. What is "romping" 2. Where can I look to find all the meanings of the abbreviated terms? i.e. , icp, pcm , etc.
Old Jul 28, 2003 | 01:58 AM
The Diesel Dude
Romp refers to an uneven running of the engine, usually at idle or low engine RPM. The ICP is the sensor that reports Injection Control Pressure to the PCM (power control module).
Go through some of these threads and one of them has a hyperlink to a virtual repair manual which spells these acronyms out.
