56 Project update..
Old Apr 28, 2015 | 06:14 PM
cdl2374's Avatar
cdl2374
56 Project update..
Been a while since i was able to post but have been busy. got motor done, aod rebuilt, all rust eliminated, widened rear fenders installed, steering column in, brake/pedal brackets done and rolled pan installed...whew...
Old Apr 28, 2015 | 06:18 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
That's looking really sharp!
Nice work.
Old Apr 28, 2015 | 08:57 PM
toby tough's Avatar
toby tough
Oh my! very nice.
Old Apr 29, 2015 | 02:45 AM
FortyNiner's Avatar
FortyNiner
Very clean looking build. Thanks for sharing.
Old Apr 29, 2015 | 08:14 AM
perks56's Avatar
perks56
Looks great, colour looks almost the same as mine.
what is your colour? Mine is cool vanilla
Be neat to see them side by side one day
Keep it up
Kevin
Old Apr 29, 2015 | 09:41 AM
cdl2374's Avatar
cdl2374
Perks56, not painted yet. That's just the epoxy . Going to end up a pearl like the motor color.
Thanks all for the positive comments...
Old Apr 29, 2015 | 03:07 PM
Justin_Entropy's Avatar
Justin_Entropy
still looks dope being in primer
Old Apr 29, 2015 | 03:24 PM
cdl2374's Avatar
cdl2374
Thanks ! I appreciate it. Lots of work getting the suspension in and all brackets fabbed .
Lexus front end, t bird rear, new motor, coil over mounts , the new welder got a work out !
Old Apr 30, 2015 | 07:55 AM
c91x's Avatar
c91x
Really interested in how your front end turns out. I think you'll be the first to actually run and drive it with the Lexus IFS.
Old Apr 30, 2015 | 08:16 AM
cdl2374's Avatar
cdl2374
Will keep ya posted . Should be awesome. I made sure to keep all the Lexus angles and dimensions , just changed out the stock coilovers with some QA1's.. It looks like it was made for our trucks.
Old Apr 30, 2015 | 08:28 AM
c91x's Avatar
c91x
How much caster did you add into the crossmember mount? Or did you keep the crossmember level. I googled caster alignment specs for the sc400 and its 2-3.5 but can't see how in the world you'd adjust it
Old Apr 30, 2015 | 08:41 AM
cdl2374's Avatar
cdl2374
By shaving the mounting bosses where it bolts to the frame.
Old Apr 30, 2015 | 10:00 AM
c91x's Avatar
c91x
Yeah I understand once its mounted you could shim or shave the mounting points. I guess i need to level out the crossmember and see if the caster is already build into the arms or if i need to angle back the crossmember when i install it
Pokee
16
Jan 21, 2017 07:18 PM
Dano78
183
Sep 11, 2015 09:25 AM
Cody_302
42
Feb 27, 2011 05:12 PM
MP&C
Paint & Bodywork
Aug 30, 2009 12:25 AM
Marz-68
16
Dec 17, 2008 09:44 AM
