old smog stuff
Old May 3, 2015 | 07:45 AM
  #76
Gary Lewis's Avatar
Gary Lewis
Thanks for the pic of the air cleaner lid!
Old May 3, 2015 | 10:39 AM
  #77
marktrot's Avatar
marktrot
Originally Posted by InfantryCPT
Pic 1. yes should be to PCV, however if the other port is going to the PCV thats fine (it should not T/or branch anywhere. Just straight to the PVC.
Pic 2. No not good for cooling, they make a special 90 formed hose, find it
Pic 3.On my truck, the larger hose, goes to my brake booster.
Then one feeds the vacuum block mounted high on the passenger side of the fire wall (almost the top) it has 2 ports of it, that vacuum block then goes to the round vac reservoir on the fender, and the other one goes to the metal tube behind the engine that is hooked to the transmission vacuum modulator.
The third one is capped.
So it looks as if you have the same, except your transmission vacuum modulator is fed directly from this port, I hope the extra vac ports on the vacuum block on the firewall are capped or run to something, otherwise you have another vacuum leak.
Me??? Have a vacuum leak??? Nope, not possible.
I think I will move the PCV back to the center of the carb for cleanliness sake. Plus the line has a mix of rubber hoses and metal tubing. I want to clean it up.
As far as the other goes, it does appear everything else has a destination or is capped. I "think" I have fixed all the leaks for now.
I will keep you guys updated. Thank you so much for all the help.
Is there a good resource for me to learn more about the electrical and vacuum system. Honestly, I want to simply understand what creates vacuum and which devices need vacuum to operate correctly so I can configure everything correctly.
Thanks yall
Old May 3, 2015 | 01:35 PM
  #78
Gary Lewis's Avatar
Gary Lewis
This is what you need, only in whatever year you have. Called the EVTM, it is worth its weight in gold. Each circuit or vacuum system is shown and explained separately rather then across several pages as in the other manuals.
Old May 3, 2015 | 05:12 PM
  #79
InfantryCPT's Avatar
InfantryCPT
http://www.ebay.com/itm/VINTAGE-1985-FORD-BRONCO-F150-350-ELECTRICAL-VACUUM-MANUAL-NEAT-/131478975113?hash=item1e9cc1f289&vxp=mtr
This one is a little closer to your year make
Old May 3, 2015 | 05:41 PM
  #80
Don Naslund's Avatar
Don Naslund
The valve (red circle) looks like an anti backfire valve for an air injection pump.
Old May 3, 2015 | 06:31 PM
  #81
marktrot's Avatar
marktrot
Thank you!!!! I am going to order it ASAP. I will be keeping you guys up to date. Thank you for all your help.
Old May 9, 2015 | 07:13 PM
  #82
marktrot's Avatar
marktrot
Well poop. Decided to pull off my EGR and this is what I find... doesnt look blocked to me
EGR and gasket
Back of manifold under carb
Old May 9, 2015 | 09:32 PM
  #83
Gary Lewis's Avatar
Gary Lewis
But, do you know if the EGR valve is leaking?
Old May 9, 2015 | 10:48 PM
  #84
marktrot's Avatar
marktrot
Not a clue. Looks all gummed up
Old May 9, 2015 | 11:02 PM
  #85
Gary Lewis's Avatar
Gary Lewis
I'm sure EGR valves can fail in a lot of ways. But I can think of three that cause problems. First, the diapragm can blow and you have a vacuum leak. Second, the valve can stick open and you have exhaust gas in the intake at all times and the engine runs poorly - especially at low speeds. Third, it can stick closed and you have no exhaust gas when you are supposed to have some. That means the engine runs rich and the economy suffers.
Old May 9, 2015 | 11:27 PM
  #86
marktrot's Avatar
marktrot
Well, my EGR was disconnected, and it appears one side of this valve is gummed up. So I am guessing it is closed.
Old May 10, 2015 | 06:27 AM
  #87
Gary Lewis's Avatar
Gary Lewis
Closed doesn't mean it isn't leaking. Frequently pieces of carbon upkeep it from closing fully, causing it to leak.
Shadowwolf66
May 12, 2018 07:32 PM
AbandonedBronco
157
Jan 11, 2018 04:34 PM
spltend
Jan 21, 2015 12:21 PM
Galm_2
24
Aug 14, 2011 09:34 PM
FromaQ
Feb 16, 2011 01:07 AM
