blow by?
Old Apr 23, 2015 | 09:52 PM
truck7575's Avatar
truck7575
blow by?
So I'm getting ready to pull my engine to redo my timing cover.. my engine has over 320000 miles on it and it runs strong, dyno'd 402 hp at the wheels recently.. I was considering dropping a reman in since im pulling the engine anyway... I heard you can test for blow by buy sitting your oil cap over the spout and seeing if the cap blows off.. well the engine tilts downward in the back so the cap just slides off but in the dark when i shine a flashlight you can see the fumes just billowing out... how do i know if this is too much... what else can i do EASILY to see if my engine has issues before i start taring it down?
Old Apr 23, 2015 | 10:00 PM
snakedoc's Avatar
snakedoc
a small amount is fine normal if the cap just slide off no need to rebuild.
the only real way is a compression test. but i would say you have a good motor,
Old Apr 24, 2015 | 05:49 PM
jhl3's Avatar
jhl3
If you have to wait until it is dark, use a flashlight, and the cap just slides off...I would say you are most likely OK.
I looked at an F450 with a flat bed recently...price was right until I checked for blow by. In broad daylight you could see it puffing. Cap did not have a chance to slide off...it was blown off. Pulled the intake boot and looked at the wheel and saw large dings with chunks missing.
Old Apr 24, 2015 | 06:38 PM
F350-6's Avatar
F350-6
As mentioned, compression test is the definitive answer. For the oil cap test, ignore the smoke. It's not about smoke it's about pressure.
Blowby will shoot the oil cap up into the air a little (or a lot) instead of just letting it slide off. If it's sliding off too quick, lay a rag over the oil fill tube and see if it bubbles up from the pressure.
Again, smoke means nothing. My truck will smoke a little or a lot depending on oil type, miles on oil, temperature, etc. It's been that way for several hundred thousand miles.
Old Apr 24, 2015 | 09:17 PM
snakedoc's Avatar
snakedoc
One sure way to know if it's bad is when it blows the oil dipstick out then you deffently need to do some work on it. And yes I have seen it more then once
Old Apr 25, 2015 | 12:22 PM
stevedrums's Avatar
stevedrums
Would disabling the glow plugs and starting a cold truck be a decent way to check compression?
at what temp should a 7.3 start without glow plugs if it has good compression?
Old Apr 25, 2015 | 02:45 PM
truck7575's Avatar
truck7575
Good question!
Old Apr 25, 2015 | 02:52 PM
jhl3's Avatar
jhl3
I think there are too many other variables involved: HPOP health, injector health, IPR health and etc. in order for that to be a decent test.
Someone else may differ....
As snakedoc and F350-6 said, a compression test is the only true way.
Old Apr 25, 2015 | 03:04 PM
stevedrums's Avatar
stevedrums
absolutely. but with a blowby test, oil dipstick, etc, plus a cold start no glowplug test, you could get an idea without having to pull valve covers and purchase tools.
Old Apr 26, 2015 | 01:38 PM
jhl3's Avatar
jhl3
While I do see where you are headed and I do agree to an extent, this will only give you an overall average. It won't definitively tell the tale on individual cylinders etc. He is going to the trouble of pulling the engine and is considering replacing it which is expensive. And the engine is relatively young for a 7.3L
There is no better time than now to do a compression test in order to decide whether to spend $5-7K or not.
Old Apr 26, 2015 | 07:14 PM
truck7575's Avatar
truck7575
What compression test would be best to perform procedure wise? There are a few different types that show different information and I've not actually done any myself before but they don't look complicated... Which will give me the information I need to evaluate my engine?
milkstake
13
Dec 1, 2018 03:46 PM
Collision
May 12, 2016 01:01 PM
s2gots
17
Nov 24, 2011 08:10 AM
7.3bo-ti-etr
Feb 21, 2011 11:37 PM
diharris
Feb 10, 2003 03:54 PM
