Too much blow-by??
Old Mar 7, 2011 | 02:31 PM
s2gots's Avatar
s2gots
Too much blow-by??
Hello people,
Yesterday I looked at two trucks, both were '99 with about 230k mikes.
I removed the oil filler cap, and turned it upside down to see If it would blow off, it did not- which is good, but there was a noticeable amount of smoke coming out of the oil fill tube, one truck was a little heavier smoke than the other. The only way I can think of describing it(it's a weird way of describing) is if someone drew a puff of a cigarette, and then exhaled, about half of that...lol...
TIA
Old Mar 7, 2011 | 02:37 PM
ju015dd's Avatar
ju015dd
sounds normal, just don't want any pressure. If your cap didnt get blown off your good to go.
Old Mar 7, 2011 | 02:38 PM
BillyBob69's Avatar
BillyBob69
My 99 is at 250K and it doesn't blow the cap off NOR does it show any smoke from the filler neck. Some others have blown cap and a littel smoke and are running good. I think it may something to do with the type and grade of oil is in there.
Have you got to test drive it? Any leaks or drips? How does it do on cold starts?
Old Mar 7, 2011 | 02:44 PM
timmyboy76's Avatar
timmyboy76
Hope thats the case, but i'm on my 3rd oil change, with each one, try'n different manuf. Currently run'n del-vac 15-40, but tryed rotella 15/40, rotella syn blend 10/30...
Old Mar 7, 2011 | 03:02 PM
BillyBob69's Avatar
BillyBob69
Hmmmm Syn 10-30? I thought it was 5-40.
Old Mar 7, 2011 | 03:33 PM
s2gots's Avatar
s2gots
Yeah drove it. Few issues. A little slow to crank but fires up fine. Starter replaced bout 6 months ago. Batteries look old, and kinda small.
Other thing is when going down the road and hit some bumps, you can hear done bumping noises line loose shocks, he said it's the bushings On the swaybars... Other than that it's seems to run normal, shifts good, super clean in and out..,
The other truck with the less smoke was sold today..
Old Mar 7, 2011 | 03:35 PM
BillyBob69's Avatar
BillyBob69
THe "bumping" is typically the bushings. If you get the truck and you go to replace them, replace the track bar bushings too.
Replace the batteries soon too. Once they give less than 10.5V it will crank but not start.
BTW... PICS!!!!
Old Mar 7, 2011 | 04:54 PM
s2gots's Avatar
s2gots
I def will post pics if i get it. I'm a little on the fence though....I would be getting it for 7k...just not 100% sure if the mileage is worth the money...
Old Mar 7, 2011 | 05:46 PM
timmyboy76's Avatar
timmyboy76
Rotella T5
- Shell Rotella T5 Synthetic Blend Technology
Old Mar 7, 2011 | 07:40 PM
F350-6's Avatar
F350-6
Mine smokes a different amount with different oil brands. The smoke amount and smell also varies between hot and cold engine and how many miles since the last oil change.
I started watching it and testing some different things back when I only had around 300,000 miles on it. I had anywhere from almost no noticeable smoke up to what looked like 3 guys blowing cigarette smoke. (steady stream, not puffs).
Pressure is the key here, not smoke. Place you're hand over the fill tube to see if you feel anything, both hot and cold. Try a ping pong ball instead of the oil cap. If there's no pressure, don't let the smoke bother you.
Don't forget to play up the high price of diesel right now when negotiating price. I just spent over $100 filling my truck up today.
Old Mar 7, 2011 | 08:21 PM
BillyBob69's Avatar
BillyBob69
Originally Posted by timmyboy76
Ahhhhhh. Ok. I use the T6 Synthetic.
Old Mar 7, 2011 | 09:21 PM
timmyboy76's Avatar
timmyboy76
LOL...that "brand" is next. Might as well hit the pacecar while i'm at it.
Old Mar 8, 2011 | 05:01 PM
s2gots's Avatar
s2gots
Any one know if the bushings are dealer only? Can I pick them up someplace local like napa??
Old Mar 8, 2011 | 05:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Clay sells the sway bar bushings, Energy suspension I believe, Riffraff Diesel: Sway Bar Bushings
Old Nov 24, 2011 | 12:26 AM
Abelexcavating's Avatar
Abelexcavating
What does it.mean if you have pressure from cap?
