Timing question + flareside Bed stakes??
Old Apr 19, 2015 | 01:26 AM
Death_Eagle_571's Avatar
Death_Eagle_571
Exclamation Timing question + flareside Bed stakes??
Hey guys, I just stumbled on a fairly recent work receipt while looking through my glove box, and on it it said the carb was tuned, the timing set to 15 degrees BTDC, and the dwell was 39 degrees. does this sound right? I have the 240ci Straight-6, and in my service manual, it said the timing should be 6 degrees BTDC. Also, Can anyone post photos of their flareside beds with the wood stakes on the sides?
Old Apr 19, 2015 | 02:40 AM
Tedster9's Avatar
Tedster9
How does it run? Starts easy, etc?. Dwell for a six is typically 36 - 38 at idle. The timing may seem a little hot, but so long as it runs well and doesn't ping under heavy load or acceleration it should be OK. May have to back it off for substandard fuel.
Old Apr 19, 2015 | 02:46 AM
Death_Eagle_571
Runs great as far as I can tell. It just seems so far off from the mfg. spec though.
Old Apr 19, 2015 | 01:20 PM
Tedster9's Avatar
Tedster9
Some Fords have two piece crankshaft balancers, the vibrations are damped by rubber in between. Not sure about the sixes, maybe that's what you're seeing though. They tend to slip off their axis as they age and make the timing marks inaccurate. Bring #1 cylinder TDC and see if the pointer indicates correctly.
Old Apr 19, 2015 | 09:28 PM
Death_Eagle_571
I didn't think about that. I think I'll just find a timing light and check it for myself.
Old Apr 19, 2015 | 09:31 PM
Tedster9's Avatar
Tedster9
Thing is, timing light is useless, if the damper has slipped, that's the point. I dunno about six banger dampers. It's pretty common with some V8
Old Apr 19, 2015 | 09:32 PM
Death_Eagle_571
Yeah, i was gonna check that first, then double check the timing to see exactly what its set at.
Old Apr 20, 2015 | 06:04 PM
P38fighter's Avatar
P38fighter
Flare side wood work
Is this what you wanted? I made these..can give you a few close ups if you want...
Old Apr 20, 2015 | 06:20 PM
Death_Eagle_571
Yeah, thats exactly what I was looking for, that looks great, some close-ups would be awesome. Period correct? I love the color of Your F100 too, thats killer!
Old Apr 20, 2015 | 06:47 PM
P38fighter's Avatar
P38fighter
I made them from scratch so whether or not they are "period" is a toss up...That color is Lexus Medium Green and has some gold in it which pops in the sun..
Old Apr 20, 2015 | 06:55 PM
P38fighter's Avatar
P38fighter
Here's the pieces
I just today took them apart to Varnish. If you need more pics after next week let me know - I should be finished with the varnish then. By the way this is Southern Yellow Pine - same as my bed.
Old Apr 20, 2015 | 09:21 PM
Tedster9's Avatar
Tedster9
Nice truck!
Rod Beauvex
May 5, 2014 02:39 PM
johnson2007
May 8, 2011 07:51 AM
DJdemon6696
Sep 22, 2007 02:52 PM
jdog34436
Dec 3, 2005 10:02 PM
