400 timing
I have a 1978 400m that was rebuilt a year ago. It has a wiand intake, holley 750 carb (probably too much), It is only cammed slighty over stock, pistons are 8.2:1, and it has a mallory unilite dist. with a hyfire ignition. My question is, what timing do you think I can get away with? Im around 16 degrees now. If you need any more info let me know.
Thanks, Jdog
335s like a lot of total timing, 39 - 42 degrees where I live and pinging no problem. You may want to set total around there then check inital. Initial timing does not mean a whole heck of much, total is most important. As long as engine starts when hot, initial timing is good. There is a hole can of worms on timing, you have to go with what works for you. No pinging and it starts, go drom there for power or fuel mileage
