64 grille j nuts
Old Apr 15, 2015 | 03:54 PM
svolpone's Avatar
svolpone
64 grille j nuts
Does anyone know the correct size for the J nuts to attach a 64 grille to a 64 2 WD flareside? Thanks.
On a side note, are there instructions on how to "join" multiple values in an advanced search here? If I search for "J Nut" i get everything with "Nut" in it. A rather large list is returned, as you can imagine. I DID try to search first.
Old Apr 15, 2015 | 04:03 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The problem is the letter J. If you search on "J nut" is throws out the "J" and just uses "nut" because (if you look close at your screen you will see this)
The following words are either very common, too long, or too short and were not included in your search: J
Old Apr 15, 2015 | 04:37 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's the thread you are after
https://www.ford-trucks.com/forums/5...-hardware.html
Have fun!
Old Apr 15, 2015 | 11:36 PM
resonateur's Avatar
resonateur
Steve,
Assuming they are the same, on my 66, the J-nuts attaching the grille to the gravel guard below are 5/16" NC, with the "plate" portion measuring about 5/8 x 1". They are the "extruded" or tubular type j-nuts, not the type with a square nut swadged in.
Old Apr 16, 2015 | 07:39 AM
svolpone's Avatar
svolpone
thanks everyone. exactly what i was looking for.
Jmatthews
Feb 21, 2013 07:54 PM
hansont
Apr 18, 2008 03:57 PM
jrv7874
Oct 31, 2007 11:54 AM
'03Beast
General Automotive Discussion
Dec 20, 2005 02:33 AM
inliner
Garage & Workshop
Mar 18, 2003 05:37 AM
