IPR nut
Old Apr 18, 2008 | 09:23 AM
hansont's Avatar
hansont
IPR nut
Second time now I've lost the nut on my IPR, any ideas on how to keep it on? loctite?
Old Apr 18, 2008 | 09:29 AM
PaysonPSD's Avatar
PaysonPSD
If there are enough threads exposed behind the nut I would get a thin jam nut to put on behind it. Any I dea why it is coming loose? What are the symptoms when it is loose, just curious?
Old Apr 18, 2008 | 09:54 AM
zx250's Avatar
zx250
Of the next Riffraff East
You may have overtightened it at some point and stripped it. Very easy to do. You could find another nut of the same size and use it. Maybe a drop of loctite. I don't think you have room for a lock nut. Main thing is do not overtighen it. finger tight plus about a 1/4 turn at most.
Old Apr 18, 2008 | 10:21 AM
SpringerPop's Avatar
SpringerPop
If you use LocTite, use Blue.
It's the weakest, but will do the job.
Pop
Old Apr 18, 2008 | 10:48 AM
PaysonPSD's Avatar
PaysonPSD
I agree with you being cautious about overtightening the nut. They didn't use a flimsy stamped nut just because it was cheaper, but to prevent the IPR from getting screwed up. My 2 cents.
Old Apr 18, 2008 | 03:57 PM
Action4478's Avatar
Action4478
Lay the nut on the bench & flatten it a bit more may help.....
You may be able to shorten the spacer & double up on the nut....
djed
19
Jan 15, 2013 09:39 AM
landstorm
Feb 27, 2011 09:34 PM
grizzly11
22
Feb 20, 2011 07:48 PM
kx450frider617
36
Nov 23, 2010 09:53 PM
jrv7874
Oct 31, 2007 11:54 AM
