no spark
Old Apr 10, 2015 | 06:25 PM
my-ford's Avatar
my-ford
no spark
been putting my truck back together.i had the engine running,then i switch the wire harness for the alternator because the alternator wasn't charging.then it wouldn't start at all,just crank and crank,no spark.so i switched the wire harness back and it still wont fire.so i replaced the magnetic pick up in the distributor. still no spark.i have power to the cap,and coil.just no spark..any idea what could cause this??
Old Apr 10, 2015 | 06:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, what are we dealing with? I would assume a stock Duraspark II or is it aftermarket.
Are you saying you replaced the pick up coil in the distributor or the reluctor?
Usually a no spark condition can be traced to a bad DS module. It's much less common for the pickup coil to go bad.
Old Apr 14, 2015 | 07:16 PM
my-ford's Avatar
my-ford
took me a few days,to find out it was just out of time...but i had checked for spark every way i could.it really wasn't getting a spark at all.and yes its just a duraspark something??? im going to go with the MSD setup.after i get a brand new,500 dollar,center force stage 2 clutch kit.too accommodate the edelbrock ,cam,lifters,intake,and soon to be a edelbrock 650cfm carb
RamblinMan1963
27
May 10, 2019 11:34 PM
allranger
20
Jan 5, 2014 02:51 PM
THAT.GUY
19
Jan 12, 2013 03:00 PM
d4e2a0d
1978 - 1996 Big Bronco
Jan 18, 2010 11:59 PM
Quackhead94ranger
Jul 2, 2005 02:40 PM
