1978 - 1996 Big Bronco
No Spark
Old Jan 17, 2010 | 01:59 PM
d4e2a0d's Avatar
d4e2a0d
No Spark
I have a 1984 ford bronco with a 300 6 cyl. I was driving it down the highway when BOOM, Lost all power and currently have no spark. I have had everything checked and it all pans out, coil, ignition module on distributor, I have actually rebuilt the distributor in the last 6 months. My wiring is fine, other side of the underhood has all been replaced, starter, alternator etc. What else is there?
Old Jan 17, 2010 | 03:34 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Time to start checking voltage readings, actually past time, might have saved you some parts. Duraspark I assume.
Old Jan 17, 2010 | 10:15 PM
d4e2a0d's Avatar
d4e2a0d
no spark
So, time to test my voltage, how do you mean? voltage of what exactly. My engine cranks over but I have no spark. I have plenty of power to my coil. What about the Engine control module under the dash? Everything electrical but that has been replaced within the last year as far as the electric system is concerned.
Old Jan 18, 2010 | 08:13 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Never can remember the changover year. If it's not a Duraspark, I can't help, sorry.
Old Jan 18, 2010 | 10:38 AM
sivart's Avatar
sivart
I had something similar happen to me this summer. Turned out to be the roll pin on the distributor gear sheared off. I had the cap off and the rotor would spin while cranking the motor so I never gave it a thought. I was getting ready to pull the distributor when I noticed I could turn the rotor by hand. Might be worth a look.
Old Jan 18, 2010 | 12:17 PM
d4e2a0d's Avatar
d4e2a0d
roll pin
Funniest thing, my roll pin is thrashed!!!!!!! I'm on the way to pick one up ASAP. Thank you and I'll let you know.
Old Jan 18, 2010 | 03:44 PM
d4e2a0d's Avatar
d4e2a0d
roll pin
You rock my socks off. That was the problem. Fired right up and is running better than ever. Thanks again.
Old Jan 18, 2010 | 11:59 PM
sivart's Avatar
sivart
Woo Hoo I actually got one right.
Hopefully you didn't have to go thru all the nonsense I did. When mine went bad, the rotor still turned with the engine so the roll pin was last thing I thought to check.
kfain71
Jan 25, 2016 11:41 AM
Moiford
Jul 16, 2015 04:37 AM
Joey4420
13
Jun 16, 2015 12:46 PM
cartmans_twin
32
Dec 21, 2011 08:11 AM
Truckasoras
Mar 30, 2001 05:20 PM
