Big Red build thread...
Old Mar 28, 2017 | 08:29 PM
  #136
agsmv1's Avatar
agsmv1
Originally Posted by Nicmike
Then your PATS module was damaged I would think. Did they replace it?
That part I need to find out. According to the body shop my PATS was not working. They started my truck from the damage the thieves had done. After repairs Ford was unable to sync the new keys with the PATS and would not start. Told them about the cluster and today the body shop got it back so evidently they were able to program the new keys. Supposed to get an update tomorrow and I will check with them. It is back at the dealer cause the turn signal switch will not reset after you turn.
Old Mar 28, 2017 | 08:31 PM
  #137
agsmv1's Avatar
agsmv1
Originally Posted by StreamOn
I didn't think PATS would work with a TS chip installed.
As far as I know PATS works with all chips and cannot be bypassed by a chip programmer, but I could be wrong!
Old Apr 3, 2017 | 08:02 PM
  #138
agsmv1's Avatar
agsmv1
Finally got her back! Couple of bugs, but working them out. Won't go into first via the gear selector so Ford has to fix that, and missing the fasteners on the bottom of the kick panel- getting fixed tomorrow! In the mean time 05 grill upgrade finally complete!
Old Apr 3, 2017 | 08:07 PM
  #139
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Originally Posted by agsmv1
Won't go into first via the gear selector so Ford has to fix that...
This is likely because they seated the lower pin on the shift tube too deep. The one that is closest to the firewall. Pull the tube, tap the pin back out about 2mm, and it should go into 1st for you.
Old Apr 4, 2017 | 07:32 PM
  #140
agsmv1's Avatar
agsmv1
Tried to rep ya, but evidently I have to pass it around! I'm going to let Ford deal with it. Got the alarm and remote start installed today, and the tech told me the PATS is still not working. He wrapped the key in foil and he is able to start it right up. Wondering if it is my chip...I know I have a new PATS installed according to the invoice as well as a bunch of other parts. The Viper disables the engine without a key so for now I will just rely on that.
Old Aug 27, 2017 | 08:23 PM
  #141
agsmv1's Avatar
agsmv1
Well all my photos are pretty much dead. Cleaned out the photobucket account and closed!
Picked up a Ranchhand rear bumper a couple of months ago...stripped it as best I could, and used some por-15 on that bad boy..
After about 4 coats, not sure why it looks grayish?
Old Aug 27, 2017 | 08:31 PM
  #142
mecdac's Avatar
mecdac
Love those NATO rounds.
Old Aug 27, 2017 | 08:38 PM
  #143
agsmv1's Avatar
agsmv1
Some new rims Fuel Vapor D569, 18X9, 4.5" backspace, and -12MM offset. Pushed the wheels out a lot more than I expected.
Old Aug 27, 2017 | 08:40 PM
  #144
agsmv1's Avatar
agsmv1
and last but not least...Plasti-dip the emblems on the fenders and rear door...
  #145
agsmv1's Avatar
agsmv1
Yep, me too!!
Old Aug 29, 2017 | 06:59 AM
  #146
wizkid00104's Avatar
wizkid00104
I used the Duplicolor bed liner in my Ranger years back. It did not adhere well and it didn't hold up in sunlight. It faded to gray and began peeling. And it offered almost no actual bed protection. I have since tried Monstaliner and although a bit more expensive it is a solid product.
Old Aug 29, 2017 | 10:04 AM
  #147
agsmv1's Avatar
agsmv1
Yep, we shall see how long it lasts. If it doesn't then I will just get it line-x'ed and be done with it..
Old Aug 29, 2017 | 06:38 PM
  #148
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Did you remove badges to plasti-dip?
Or just spray and then remove overspray?
Looks awesome
Old Aug 29, 2017 | 07:54 PM
  #149
hwybee22's Avatar
hwybee22
You don't need to remove them. Just tape around them for overspray. It doesn't have to be perfect, but the crappy plastic dip i had was extremely hard to peel off around the badge. I put 5 coats on mine.
Old Aug 29, 2017 | 08:37 PM
  #150
fordboy67's Avatar
fordboy67
I have wondered how the Plastidip holds up.
