Three speed on the column issues.
Old Apr 5, 2015 | 10:34 PM
rangerottis's Avatar
rangerottis
Hello all! I have a 70 f100 with a 302 in front of a 3.03 column shift transmission. Everything seems to be smooth, but when I'm in 2nd and not keeping pressure on the drive train, it slips out of gear. It doesn't fall all the way out, just enough as to not mesh. If I try and shift it back without pulling it back down in neutral, it rakes badly. Any ideas?
Old Apr 6, 2015 | 11:22 AM
kenny nunez's Avatar
kenny nunez
2nd gear
It almost sounds like the body mounts may be the cause. Usually when the problem is internal the transmission jumps out under acceleration.
Old Apr 6, 2015 | 11:49 AM
rangerottis
The body mounts are solid with no rust at all. The only rust is the right hand floor pan, and under the battery box. Could the linkage need some tweaking? If so, how would I go about it?
Old Apr 6, 2015 | 01:53 PM
kenny nunez
2nd gear
Are the shift levers on the base of the steering column tight or sloppy, also what shape are the grommets at the transmission levers. Did this just start, or has it started gradually. Are the motor mounts still in good condition. You may have a worn out shift tube. If you look close at the base of the column there is a place to insert a pin that alines the levers in the neutral position to center them . Make sure the levers are tight on their shafts on the transmission. If all of this checks out then you may have some internal transmission problems.
Old Apr 7, 2015 | 09:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Popping out of 2nd gear usually caused by worn 2/3 syncro brass blocker rings.
Bulldawg1081
18
Mar 8, 2013 07:17 PM
SNEWTON
Oct 8, 2008 04:26 PM
turbotim2379
Feb 10, 2007 01:03 PM
dtherren
Apr 3, 2006 11:46 PM
badcuda
Apr 25, 2005 03:35 PM
