Vibration
Old Apr 3, 2015 | 03:15 PM
19711969's Avatar
19711969
Vibration
Ok need help from the experts. At 50mph and up I have a lot of vibration clutch in or out.
I know I'm not providing a lot of info but I'm just not sure what else to say about it. Hoping you guys might have the magic fix.
1971 300 6cyl rebuilt did same thing before the rebuild.
Old Apr 3, 2015 | 03:24 PM
f5fordgirl's Avatar
f5fordgirl
Are you sure you have the 300 flywheel and not one from a sb. If its right, the bushing in the trans tail housing will wear, causing a vibration.
Old Apr 3, 2015 | 03:28 PM
HIO Silver's Avatar
HIO Silver
You'll need to isolate the source a little further...
Look for a missing wheel weight, loose lugs, or a zip-tied a wrench attached your driveshaft, etc.
Check for loose nuts, bolts, or worn suspension & steering components.
Try rotating your tires.
Old Apr 3, 2015 | 03:38 PM
19711969's Avatar
19711969
I feel sure I'm the first person to have the motor out.
Is there any way to tell for sure which flywheel I have? The only thing I remember about it when I had it out was it had balance holes drilled in it.
Also what is sb?
Old Apr 3, 2015 | 04:06 PM
f5fordgirl's Avatar
f5fordgirl
The 300 flywheel will be smooth on the back side, maybe some balance holes, but the sb, (small block V8) 260, 289, 302 will have a balance weight.
Old Apr 3, 2015 | 05:08 PM
19711969's Avatar
19711969
Ok it didn't have balance weights. I feel like it is the right flywheel. Thanks for the help.
Old Apr 3, 2015 | 05:13 PM
19711969's Avatar
19711969
Thanks!!! Hio Silver I will definitely be looking into it. And lol on the drive shaft
Old Apr 3, 2015 | 08:26 PM
ultraranger's Avatar
ultraranger
A good while back. I had a vibration problem with my truck ('69 F100, 240, C-4) starting at about 35 MPH and up.
It turned out to be the drive shaft U-joints. Many of the needle bearings in the U-joint cups were either broken or ground up into metallic dust!
After I replaced both drive shaft joints, the vibration problem on my truck went away.
Old Apr 3, 2015 | 08:53 PM
HIO Silver's Avatar
HIO Silver
Btw, leave the wrench out of it and it's a harmless practical joke... Get a really looong zip tie, secure it to your friend's driveshaft and leave the tang end long so it slaps the body or bed when you pal starts to drive away.... More better if you shoot a video for posterity's sake.
Be prepared to scoot when your pal discovers what you've done.
Please post back your corrective action for filing in "the knowledge base".
Old Apr 3, 2015 | 08:58 PM
19711969's Avatar
19711969
Thanks again replacing the U-joints soon.
Old Apr 4, 2015 | 09:06 AM
19711969's Avatar
19711969
Well I decided to put the back end on blocks and watch things while turning. It turns out the drive shaft has a pretty good bend in it that became more obvious the higher the speed.
Any ideas on where to find a drive-shaft that will fit a 1971 short bed?
Old Apr 4, 2015 | 09:29 AM
HIO Silver's Avatar
HIO Silver
I'm kinda wondering how it got bent..... all of a sudden.
Craigslist, salvage yard, FTE market place, or try your state FTE chapter. Or have one made.
You're in Texas, right? Isn't there like bazillion trucks in Texas??
Old Apr 4, 2015 | 03:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-6375-N .. Flywheel - 164T Ring Gear - Use with 11" clutch / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle.
Applications: 1965/66 F100/250 240/300 I-6 2WD - 1967/74 F100/250 240/300 I-6 2WD/4WD & F350 - 1975/76 F100/250 300 I-6 2WD/4WD & F350.
240 I-6 cancelled at the end of the 1974 model run.
Old Apr 4, 2015 | 09:24 PM
19711969's Avatar
19711969
Thanks numberDummy
Old Apr 5, 2015 | 06:22 AM
sweetlou1's Avatar
sweetlou1
You know, if its not your DS, take a long look and feel your tires. One or more may be separating on you and it will do the same thing before it blows. Desert heat and Texas heat seem to do this a lot.
