Steering Column Shifter on a 73 Automatic
Old Apr 1, 2006 | 08:50 PM
dtherren's Avatar
dtherren
I am having linkage problems on the column. What am I going to find and can I fix it? Or replace complete column?
It is hanging up when trucing to shift from R to D, and visa versa. .
Thanks
Old Apr 1, 2006 | 09:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Many times that is caused by rotted out or bad cab mounts. Check your cab mounts first.
Old Apr 1, 2006 | 09:03 PM
Mil1ion's Avatar
Mil1ion
Usually it is caused by a wornout parts.
Old Apr 2, 2006 | 09:44 AM
dtherren's Avatar
dtherren
You guys are probably both right to some extent, in my case. I do have a cab mount in pretty bad shape, which would effect the alignment of the shift levers and rods.
On the other hand, all the linkage is tight, except in the column. The top part of the column, where the shift indicator is loose. I was thinking it was more in the shift lever.
Can I get replacment parts anymore? Can it be tightened?
Thanks
Old Apr 2, 2006 | 11:34 AM
ShadowWulf's Avatar
ShadowWulf
Heh, ok i have a bit to say about this myself as im going through this on my '73 and it turned out to be a PITA.
Pulling the colum apart was easy. I got everything removed and catorgized (my broken piece was the lever in the inside where it hits the pin.)
Howvere after 2 junkyard runs im still stuck in a hole. I pulled a complete colum out of a 74 and a 78. THEY WERE DIFFERENT than my 73. On the 73 the shift indicator sits on the colum. Ob the others i puled its on the dash at the vase of the colum. Internally the pieces were ALMOST the same but not quite as some of the internals seem to be fliped from top to bottom. End result was that nothing matched up. I think i just need another 73 truck to make it work, as i wasnt aware they changed the colums within one year.
Just something to keep in mind as it seems 73's can have some very minute differences from a 74+ it seems (or i have some mutant truck).
Old Apr 2, 2006 | 03:12 PM
dtherren's Avatar
dtherren
Well, ....
That just made up my mind about putting in a floor shifter.
I drive my truck everyday, and cant have it down because I cant get parts or fix what is there..........
Thanks!
Old Apr 2, 2006 | 03:16 PM
dtherren's Avatar
dtherren
Unless.............
I could find a tilt wheel out of a newer truck, or even car that would fit the 73 F100 and just swap out the complete column.........
I wonder if a tilt out of an older LTD or T-Bird would fit?
Thanks.
Old Apr 2, 2006 | 03:36 PM
Sgt Wonderful's Avatar
Sgt Wonderful
dtherren, try ebay for parts.
Old Apr 2, 2006 | 03:52 PM
dtherren's Avatar
dtherren
ok.
Thanks.
Last edited by dtherren; Apr 2, 2006 at 03:53 PM. Reason: duplicate post. didnt think it posted
Old Apr 3, 2006 | 11:46 PM
Mil1ion's Avatar
Mil1ion
Check posts by Dfisher for fabrication for making car tilts work.
You need a 73-76 column.
Why ?
'Because In 77, the hazard light switch went to the column.
In 78 the NSS went to the tranny for mounting.
Getting a tilt from a 78/79 with still make you do some fabricating with the, NSS, Harzard switch.
