Ford 460 egr
Old Apr 4, 2015 | 05:09 PM
Natcox012's Avatar
Natcox012
OK so checked codes. Got 11 which is system pass. And 10 and I'd how I got a 10 when the chart goes down to 11. Any ideas?
Old Apr 4, 2015 | 05:51 PM
rla2005's Avatar
rla2005
Many code readers interpret the separator flash between KOEO and CM codes as Code 10.
Old Apr 5, 2015 | 06:18 PM
Natcox012's Avatar
Natcox012
Dumb down please new to the codes.
Old Apr 5, 2015 | 06:52 PM
subford's Avatar
subford
When reading the Key On Engine Off (KOEO) codes there is a pause with one flash after the KOEO codes (electrical self-test) and the codes stored in the memory of the computer when the Continuous Memory Test was ran while driving is read out known as CM codes.
The one flash at the pause as said above is displayed by most code readers as a 10.
See the one flash at the pause in the image below.
Old Apr 5, 2015 | 06:58 PM
Natcox012's Avatar
Natcox012
Soooo.?? There is nothing wrong?
Old Apr 5, 2015 | 07:04 PM
subford's Avatar
subford
For nothing wrong you should have gottern on your reader a 11, 11, 10, 11, and another 11.
The second two 11's are CM codes and the first two are from the KOEO Electrical test.
Note there are sensors that can be bad and you will still get a 11 in the KOEO self-test for example the ECT and IAT sensors. These two sensor can make for hard starting when the engine is warm or the other way around.
wicat3
20
Aug 28, 2012 06:16 AM
BOLINJORDAN
Aug 14, 2009 08:17 PM
jinx102672
1983 - 2012 Ranger & B-Series
Jul 25, 2005 07:57 AM
BigDuVall
Mar 17, 2005 08:43 PM
kc5deb
1997 - 2003 F150
Oct 22, 2004 03:11 PM
