Need help with emissions (Again!!!)
Old Jul 13, 2005 | 07:50 AM
jinx102672's Avatar
jinx102672
Exclamation Need help with emissions (Again!!!)
I'll try to keep it short, but I want to give you all the info.
2 months ago: Replaced DHCP sensor, EGR valve, EGR solenoid & ran code reader KOEO, KOER and CM codes all came up 111 or 10. (Thanks for everyones help )
Yesterday: Wife driving home and engine overheated. I added coolant which solved the overheat problem. Engine started running rough so I pulled the codes and this is what came up
CM = 211 profile ignition pickup circuit fail
KOEO = 111
KOER = 172 HEGO senor fault/lean
332 insufficient EGR flow detected
I reset the computer without fixing anything, drove it around and pulled the codes again and this is what I got:
CM = 10 (all clear)
KOEO = 111
KOER = 332 insufficient EGR flow detected
411 cannot control RPM during KOER low RPM check.
My questions are:
1. Could the engine overheat have caused the codes and could it have cause a malfunction/failure of any of the parts I replaced?
2. Could a clogged cat cause the EGR problems that the code reader is pulling?
By the way I can't find any coolant leak and I'm not burning it. Flushed the system 2 years ago. So where is it going?
Old Jul 13, 2005 | 09:48 AM
diskguy's Avatar
diskguy
I don't know the answer to your other questions but I just solved a 332 code. Check all the vacuum lines to EGR, EVP and EGR control solenoid. Maybe a line melted or got disconnected in your overheat. Good luck!
Old Jul 13, 2005 | 10:32 AM
jinx102672's Avatar
jinx102672
Yeah, I've already checked all the vac. lines and they are in good shape. No melting or leaks. A buddy of mine said the coolant issue might be due to a bad head gasket (god I hope not), and the EGR codes might be comming from excess pressure due to a clogged cat.
However, I would still like more opinions on this issue.
Thanks.
Old Jul 13, 2005 | 12:07 PM
rich2481's Avatar
rich2481
Have you tried disconnecting the battery for a couple minutes to allow the computer to reset? I usually do this anyhow, just a pain to reset the radio but wont hurt anything else,
Old Jul 13, 2005 | 12:15 PM
jinx102672's Avatar
jinx102672
Yes I have. Disconnected once as posted earlier and disconnected again this morning. Still pulling the 332 and 411 codes.
Old Jul 14, 2005 | 06:35 AM
pawpaw's Avatar
pawpaw
Which engine are we talking about here????
Old Jul 14, 2005 | 07:29 AM
jinx102672's Avatar
jinx102672
1994 2.3L Ford Ranger. I've got it going in to the mechanics this morning. Hopefully it's not serious.
Old Jul 14, 2005 | 03:12 PM
jinx102672's Avatar
jinx102672
Exclamation The results are in...
The Mechanic narrowed it down to one of two possibilities. The DHCP or the EGR solenoid. I replaced the DHCP first but that was not it. So I looked at my old post ( clicky ) and found that after replacing all of EGR stuff and still having the problem, I put on a new TPS. Which is what I'm fixing to go buy. I'll keep you posted.
Old Jul 15, 2005 | 09:20 AM
rich2481's Avatar
rich2481
I would think you could spray carb cleaner at the EGR valve to see if it was leaking,, I have gone so far on my one BMW as to take a garden hose and soak the engine to find a vacuum leak,
good luck, the Mitchells manual should tell you how to test the TPS.
Old Jul 15, 2005 | 09:31 AM
jinx102672's Avatar
jinx102672
Well I have good news and bad news.
The good news is:
The cat is not clogged.
Found the coolant leak.
The Heads and gasket are intact.
The bad news:
radiator is cracked from age, gonna replace it.
purchased new TPS and EGR solenoid.
Planning on replacing what I can this weekend.
Old Jul 18, 2005 | 07:19 AM
jinx102672's Avatar
jinx102672
Replaced the radiator this weekend. It took about 2 hrs. since it was my first radiator exchange ever and I didn't want to mess anything up.
Replaced the TPS as well and re-ran the codereader. The 411 code is nolonger showing. So apparently the engine got hot enough during the over heat to affect some components.
Still waiting for the EGR solenoid to come in the mail to help with the 332 code.
Thanks for the help everyone.
Old Jul 22, 2005 | 08:28 AM
jinx102672's Avatar
jinx102672
Thumbs up Update
Well the new EGR solenoid came in yesterday. Replaced it last night, cleared the codes and drove it. The results......
It's all good
The engine bay must have gotten pretty darn hot in order to mess with those parts. I've got another Idea, but I'll save it for another thread.
Thanks to all who helped.
Old Jul 22, 2005 | 08:39 AM
pawpaw's Avatar
pawpaw
Good to hear you're "on the road again" !!!!
Good feedback too.
Old Jul 22, 2005 | 09:19 AM
diskguy's Avatar
diskguy
Smile
It's a good feeling when you solve one!
Old Jul 25, 2005 | 07:57 AM
jinx102672's Avatar
jinx102672
Thumbs up One more piece
Drove it for 3 days and It's throwing a code for insufficient EGR flow.
When to the store, yada yada yada,
Put in a new IAC valve with results listed below
KOEO 111
CM 10
KOER 111
I also put in 2 zip ties on the end of the accelerator cable to take out some slack. Works good.
SleeprLegend
19
Jan 12, 2012 09:41 PM
BRay09
15
Mar 5, 2011 02:44 PM
ErickSaint
Oct 28, 2006 11:08 AM
jinx102672
May 11, 2005 08:08 AM
