What do these Check Engine codes mean?
Old Mar 13, 2005 | 07:23 PM
BigDuVall's Avatar
BigDuVall
Code:
 1994 Mazda B4000
4.0L Auto
Memory Code 124
TPS/Pedal Position
Higher Than Expected
Memory Code 214
Cylinder ID
Circuit Malfunction
Memory Code 327
EGR Sensor
Below Min Voltage
Memory Code 332
EGR Flow
Insufficient
My guess is that the EGR valve has some carbon buildup, and maybe there's a problem with the intake or TB. This is my dad's truck and I finally got him to get the codes scanned, because I knew there was something wrong with it. What do all these mean?
Old Mar 13, 2005 | 09:41 PM
BigDuVall's Avatar
BigDuVall
Nobody knows? I'd be a Chevy forum could probably answer it.
Old Mar 14, 2005 | 04:12 PM
60f100trk's Avatar
60f100trk
is the truck pinging running rough stalling?
check in the Technical Information posting if its a '94 it should be under the "more EEC-IV codes" link
youre on the right track with the egr carbon, id also search this forum for the DPFE its the little aluminum box that controls egr function, i guess its a common problem
-Sam
Old Mar 14, 2005 | 07:36 PM
Ken00's Avatar
Ken00
There are pinpoint tests to determine the exact cause for each code, you should run these tests. I can email you the ones for the 124, 327 & 332.
Old Mar 17, 2005 | 05:31 PM
RangerRuss's Avatar
RangerRuss
Will this help at all?
http://autorepair.about.com/cs/troub...l_obd_main.htm
Russ
Old Mar 17, 2005 | 08:43 PM
Ken00's Avatar
Ken00
ODB-II is for newer trucks, not the same codes.
jdthedj10
Jan 11, 2016 04:15 PM
BrownTrash
Mar 16, 2015 05:14 PM
94wyatt95
Aug 6, 2014 09:32 PM
Bad Bad Leroy Brown
Jun 7, 2014 11:36 AM
CentralMassLandscape
Apr 20, 2014 02:32 PM
