Ford 460 egr
Old Mar 31, 2015 | 08:32 AM
Natcox012's Avatar
Natcox012
Ford 460 egr
Well last night was taking a back road and got the truck slightly stuck. Finally got it out by mashing it . Got turned around had a little mud fun. And mashed again halfway through my spin truck died. Got out lift the lever on the radiator cap to release pressure and cool off. Always starts easier. Waited few minutes started right up. Any ideas?
Old Mar 31, 2015 | 12:28 PM
timbersteel's Avatar
timbersteel
Sorry Nate, but I got completely lost 1/2 way through your post.
What part of the title has anything to do with the lever on the radiator cap?
Can you interpret your post and clarify in complete sentences why you are asking about the EGR?
Not trying to be rude, but I couldn't even understand the paragraph and it's relation to your post.
Old Mar 31, 2015 | 01:27 PM
Natcox012's Avatar
Natcox012
Yea sorry. Got my 88 Ford 250 stuck at the bottom of a hill mashed the Gas all the way back up the hill and into a field doing about half a doughnut. Then it just died all the sudden. It was warm because smoke from coolant was happening so I released the pressure to cool off faster thinking it would help. Let. It set not even long enough to cool off tried starting and fired right up. It figured due to it just dieing all the sudden. Making a popping on deceleration. And a check engine light that comes on when it wants. It could be egr
Old Mar 31, 2015 | 01:49 PM
rla2005's Avatar
rla2005
The Check Engine Light is trying to tell you something...quit guessing...check for codes.
Warm up the truck then do this: http://web.archive.org/web/201104301...tion.com/?p=13
Or purchase a Code reader such as the Equys/Innova 3145.
Run the Key On Engine Off (KOEO) tests and stored (Continuous Memory CM) code display. List the codes by number and when they were displayed. Stating you received "No Codes" means you did not run the tests correctly. At the very least you should receive Code 11 "System Pass" if there are no issues found.
Old Mar 31, 2015 | 09:25 PM
Natcox012's Avatar
Natcox012
Ordered the scanner. And also the truck idles funny now. And more cranking time when starting.
Old Mar 31, 2015 | 09:28 PM
ponykilr's Avatar
ponykilr
Might have bad head or head gasket if it got way hot.
Old Apr 1, 2015 | 03:56 AM
Natcox012's Avatar
Natcox012
I don't think it's head gasket yet cause it hasnt blown coolant all over. And temp gauge stayed alright but we all know how they work.
Old Apr 1, 2015 | 04:14 AM
krooser's Avatar
krooser
Releasing the pressure in the radiator will only cause the coolant to boil. It will not allow the engine to cool down faster.
Old Apr 1, 2015 | 05:47 AM
Natcox012's Avatar
Natcox012
But would releasing the pressure take out the hot air pressure and cool. And some of the coolant went into the resivior so it was exposed to cool air more.
Old Apr 1, 2015 | 06:26 AM
subford's Avatar
subford
No it would not.
Old Apr 1, 2015 | 06:47 AM
Natcox012's Avatar
Natcox012
Ok. So back to square one what made it die? I also believe might be a small short in the ignition lock cylinder. Or key ignition
Old Apr 1, 2015 | 07:08 AM
subford's Avatar
subford
You will find that out more than likely when you get the scanner if you do not unhook the battery before you look at the codes.
Those scanners cost a lot more than a code reader. The Code reader such as the Equus/Innova 3145 that ral2005 suggested above for only about $30.00 would have worked just fine.
Old Apr 1, 2015 | 07:32 AM
Natcox012's Avatar
Natcox012
Yale a that's the one I got
Old Apr 1, 2015 | 07:58 AM
rla2005's Avatar
rla2005
So...have you used your code reader to run the KOEO tests and stored code display?
Old Apr 1, 2015 | 07:59 AM
Natcox012's Avatar
Natcox012
No not yet Comes in mail sat.
