Neutral Safty switch
Old Mar 27, 2015 | 10:10 PM
Misouri's Avatar
Misouri
Hey guys i wondering if you could help. I pull my 302 fmx from the p o. It was hacked up to begain with. So a 400 c6 went back in. I did nt mark the neutral safety switch. I ve looked at wiring diagrams, but I can t find what plug it is. Anyone know the color of wires or and the plug? Thanks
Old Mar 27, 2015 | 10:22 PM
Misouri's Avatar
Misouri
Sorry it s a 77
Old Mar 27, 2015 | 10:36 PM
bkaul's Avatar
bkaul
Does the FMX even have a transmission-mounted switch? I just pulled the 302/FMX the PO had in there out of mine, and my NSS is in the steering column on my '74 ... don't recall seeing any provision for it on the FMX, though I could've missed it. And there's no reason you would've removed a column-mounted switch when swapping, right?
Old Mar 27, 2015 | 10:54 PM
Misouri's Avatar
Misouri
Should have added the trucks a 77 and the engine and tranny is a 81, the trans has two wires with a plug that reaches up around the brake booster. Do I need to have it connected for my truck to start and have back up lights
Old Mar 27, 2015 | 11:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Does you truck have a neutral safety switch on the underside of the steering column?
Read up on NSS /back up lights here. https://www.ford-trucks.com/forums/1...easy-wire.html
Steering column switch looks like this, well sort of. It is normally attached to the columb 9R/H pic) and not hanging from a zip tie and have a screw in it. AKA red neck NSS bypass.
Old Mar 27, 2015 | 11:40 PM
Misouri's Avatar
Misouri
I can not find anything under the dash, I did change the column to a 79 tilt if that makes a difference
Old Mar 28, 2015 | 04:25 PM
Misouri's Avatar
Misouri
But I wondering what wires I need from the truck for the n s s
Old Mar 30, 2015 | 02:48 PM
I_Am_Ozymandias's Avatar
I_Am_Ozymandias
Mine had been moved by the P.O. but the plug from my 76 F100 was located behind the instrument panel/gauge cluster towards the left side. Almost in between the gauge cluster, and the wiper switch.
Mine looks exactly like this:
One wire you can easily find is coming from the back of your keyed ignition switch. RED wire with BLUE Stripe. This wire goes from the ignition, straight over to the Neutral Safety Switch plug. If you have a wire probe, and a continuity tester you can run it down in short order.
Old Mar 30, 2015 | 05:30 PM
Misouri's Avatar
Misouri
Ok thanks for the help I'll try looking
Old Mar 31, 2015 | 06:45 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Since your truck is a '77, look under the dash, around the steering column. There should be a flat 4 wire connector that looks similar to a trailer light plug. It will have four wires going to it, two red w/ blue trace and two black w/ red trace. This will be the connector for the neutral start switch. Two of the wires are for the neutral start circuit and the other two are for the back up lights.
Just so you know, in '78 Ford moved the NSS to the side of the transmission. It surrounds the shift arm.
Old Mar 31, 2015 | 10:01 AM
Misouri's Avatar
Misouri
Ok thanks so how would I make it work my tranny only has two wires from it
Old Mar 31, 2015 | 10:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Sounds like someone may have cut off two of the wires, there should be four. Take a close look at the switch and see if there weren't originally four wires. If that's the case you'll need to replace the switch. After that, you can lengthen the wires and run them to the plug under the dash
AKCorinna
Sep 8, 2015 02:52 PM
g-man-75
Jul 28, 2014 08:53 AM
1981fordstepside
15
May 14, 2014 05:21 AM
rwlacks
Electrical Systems/Wiring
Nov 24, 2008 10:47 PM
RAILMAN
Mar 14, 2001 11:25 PM
