Please help 01 7.3 a/c
Old Mar 26, 2015 | 11:48 AM
mototrig's Avatar
mototrig
Oh sorry bout that. The way I was reading it made it seam more in depth and possibly damaging to the system. Good to know.
Old Mar 26, 2015 | 12:22 PM
David7.3's Avatar
David7.3
Originally Posted by bigb56
You missed the whole point of my post. Starting at the pressure switch takes less than a minute and only requires a bent piece of wire and proves out everything down stream including the harness you are referring to. No meter, no pulling wires apart. Just standard flow chart procedure.
If you do it for just a second even an empty system, no damage will be done to the compressor. I am certified in A/C, 134a systems can be done by the home owner, you can buy the freon and add, they have high and low switches so you cant over charge a 134a system, it just will shut the compressor off, if the system is empty and you see a hole or broken line, unless you have a vacuum pump that will reach 29.8 inches of vacuum than you need a pro to do the evacuation. moisture in the system will give you problems down the road, not worth it, make the repair and bring it to a qualified shop and let them pump it down for an hour, that will remove all moisture and they can even add oil with a dye that shows up on a blue light, so in the future you can check for leaks yourself. The newer systems the A/C is controlled by the ECU, and it monitors all kinds of info, outside temp, evap temp, low and high side pressure, compressor rpms, those you just cant jump out a switch and see if it's low, but you can see with a scan tool what the pressures are. sorry just rambling on. I think you have a good idea of what you have to do. the compressor is good, clutch and coil are good, just need to get power to her, I bet she is low. My 2 1/2 cents.
Old Mar 26, 2015 | 03:30 PM
joshua6430's Avatar
joshua6430
Originally Posted by SpringerPop
Need a wiring diagram of the system?
Pop
Yes , might be helpful , I jumped the compressor and hooked ac guage it was reading 40 psi , a/c also blew nice and cold while I had it jumped . would there be potential dangers on running it jumped ??? . also I can seem to find a bad fuse so what could it be maybe the cycling sensor ???
Old Mar 26, 2015 | 03:50 PM
joshua6430's Avatar
joshua6430
Anyone have the wiring diagram I'm going to chase the wire back to fuse panel to see if maybe the wire got spliced from previous owner . I got this truck blindly not knowing the issues with it so it just trouble shoot and fingers crossed . but it seemed fine when I jumped wires . what I did was grab a negative and positive and clipped them to the compressor itself . the guy at advanced said its the sensor more than likely . the sensor that is on the low pressure side right beside compressor .
Old Mar 26, 2015 | 05:04 PM
joshua6430's Avatar
joshua6430
OK I just ordered a new cut off switch for the low side to see if that was the issue we will find out tomorrow 😑
Old Mar 26, 2015 | 05:57 PM
Pikachu's Avatar
Pikachu
I'm going to go out on a limb and guess your system is undercharged.
Old Mar 26, 2015 | 07:56 PM
bigb56's Avatar
bigb56
Poor man's quick and dirty way to check charge, Run AC with slightly elevated idle, grasp line at bottom of evaporator and line at top of evaporator. If bottom is cold and top is warm it's low. Same principle as those stick on thingys they used to sell.
Old Mar 27, 2015 | 07:33 PM
SpringerPop's Avatar
SpringerPop
Wiring Diagrams, though for a 2000, should be the same.
Pop
File Type: pdf
File Type: pdf
Old Mar 28, 2015 | 04:39 PM
joshua6430's Avatar
joshua6430
its fixed !!!
OK my low pressure switch came in today and I installed it ! The compressor kicked in , shortly after kicked out I checked freon and it was really low . so I tapped the clutch plate with a screwdriver it kicked back on and I added more freon . my psi is right at 33 I'm going to buy another can and bump it up to 40.I appreciate everyone's help !!!
Old Jul 19, 2015 | 11:05 AM
mikenamys's Avatar
mikenamys
Here is how I charge mine...to revamp an old thread now that it is hot EVERYWHERE!!!
@50-55 psi on the low side then 100 + the ambient(outside) temp. on the high side. So if it is 85 degrees outside your high side should be 185 psi.
Now my wifes Tahoe blows damn near ice at 45 psi and the same principal for the high side.
My 2 cents...
90pioneer
Sep 6, 2016 10:41 PM
lestro
Jun 1, 2010 09:31 PM
gofast51004
Nov 24, 2009 07:56 PM
michaelbrainardatwor
Dec 9, 2007 08:01 AM
jonathandennell
Oct 1, 2006 08:34 PM
