AC compressor clicking like crazy
Old Sep 3, 2016 | 03:01 AM
90pioneer's Avatar
90pioneer
2003 7.3, AC compressor clicks like crazy. Can he heard outside the vehicle while idling.
The round disc on the front of it is what is making the noise.
The AC used to work awesome but now only blows cool air for about 10 minutes then turns luke warm.
Is the clutch on my compressor bad? I have heard they can be adjusted, but not sure how.
Old Sep 3, 2016 | 05:03 AM
Pikachu's Avatar
Pikachu
It sounds more like the system charge is low or there's a restriction. It would be a good idea to get a set of gauges on it to see what's going on.
Old Sep 3, 2016 | 11:16 PM
BadDogKuzz's Avatar
BadDogKuzz
If I recall correctly the a/c compressor clutch should only have .020 gap when the truck is off. It could be a bad clutch or it could be the clutch cycle switch which is on the drier. It could have a clogged expansion valve if that is the case then that means the compressor is going bad or is already chewing up parts inside it.
Or it could be something as simple as you have a leak somewhere and needs more feon.
Old Sep 3, 2016 | 11:27 PM
timmyboy76's Avatar
timmyboy76
Mine was doing the same thing prior to summer starting. Removed the clutch and the last shim that's was in there. Reinstalled clutch and alls "cold". Did however, order a new clutch assy from rockauto since there's not much clutch left
Old Sep 4, 2016 | 11:47 AM
empiretc's Avatar
empiretc
was having this issue. it turned out to be the WOT relay was malfunctioning.
Old Sep 6, 2016 | 03:27 PM
brian42's Avatar
brian42
Veteran: Navy
Mine required an air gap adjustment when it did that:
https://www.ford-trucks.com/forums/5...ml#post4464164
Old Sep 6, 2016 | 10:41 PM
KJNDIVER's Avatar
KJNDIVER
My bet is either one or both of your switches may be bad or just a bad connection on the terminals. The low pressure switch is on the dryer/accumulator and the high pressure switch is near the compressor. I dealt with this twice earlier this year on my truck and my dads and both were switch related.
tractorboy924
Jul 13, 2017 11:26 AM
spdjunke
Aug 8, 2005 09:56 AM
masseysbronco
1978 - 1996 Big Bronco
Jul 26, 2005 02:22 PM
markcrane
Aug 4, 2003 12:26 PM
Lakeitel
Jul 31, 2003 07:00 PM
