Throttle Sensitivity
Old Mar 18, 2015 | 08:48 AM
Superduty450's Avatar
Superduty450
2006 F150 2X4 CC; I am having problems with throttle sensitivity, it's just when taking off from idle. When taking off it's gives too much throttle, not capable of smooth takeoffs. Any ideas like reprogramming or what parts to replace?
Old Mar 18, 2015 | 11:12 AM
bbender85's Avatar
bbender85
i have this too on my '07, where no matter how smooth and linear i depress the throttle it seems like the throttle body is opening on it's own terms. being drive-by-wire i am wondering if the butterfly or mating surface on the bore is dirty; i have a can of TB cleaner waiting for warmer weather and some free time to pull it out and inspect/clean it. i also have a intermittent-in-intensity miss at idle (have addressed the usual miss-at-idle suspects already).
i'll be curious to what other responses you get.
Old Mar 18, 2015 | 10:32 PM
P.Bronner's Avatar
P.Bronner
My 05 - 5.4 does this some times. I also notice that sometimes if I just barely tip into the throttle it will surge lightly. I suspect a good cleaning of the intake throat and throttle blade will cure it.
Old Mar 19, 2015 | 08:57 AM
Superduty450
I will give it a good cleaning then, time to change out the spark plugs also
Old Mar 19, 2015 | 02:31 PM
motolorenzo's Avatar
motolorenzo
Throttle Surge
Good Luck Guys. My 04 Lariat 4X4, 5.4 Drive by Stupid Wire has done the surge since new. It is intermittent so naturally when under warranty the dealer could not detect it. The dealer here on the Big Island, Hi. said its probably in the ECU. Not really a problem most times unless you are trying to be exact with the throttle like backing up to a Big Boat trailer or like that. I just live with it. HOWEVER, if one of you guys finds the fix I'll try that too. A Big Aloha to ya, Renzo
Old Mar 23, 2015 | 01:40 PM
bbender85's Avatar
bbender85
well i finally had the time to pull off my TB this weekend.
before:
after:
i am reluctant to report no change in drivability whatsoever. i also still have the rough'ish idle i was hoping this would remedy.
Old Mar 25, 2015 | 04:42 PM
1saxman's Avatar
1saxman
Well, there's always the MAF sensor wires to clean. Get the special cleaner.
Old Mar 25, 2015 | 06:15 PM
bbender85's Avatar
bbender85
yeah, going to give that a try. I did remove and inspect and they look perfectly clean, but not sure how much weight a visual inspection holds.
sail2244
1983 - 2012 Ranger & B-Series
Mar 6, 2010 07:03 PM
98FordTruck
1997 - 2003 F150
Feb 14, 2008 03:11 AM
Firewiz
2004 - 2008 F150
Jun 14, 2004 04:57 PM
MisterCMK
Jan 21, 2004 08:34 PM
Mzche
Jul 23, 2001 01:26 AM
