The od light flashes... I have a great reverse but when I put the sucker in D it feels like I'm trying to burn out in 4wd. But when I put it in 2 or 1, it seems to be a tad sluggish but it gets er going. It feels like I have only 2nd and 3rd but they feel weak. I replaced the solenoid pack and I still have this problem. Once in a great great great blue moon, I can get 1st, 3rd and of. But no 2nd, unless if I manually put it in 2, then let off the pedal and put it back in D it goes to 3rd then of/4th. When it does seem to work... Somewhat fine... It goes from 1st and slams into 3rd and about 30-35 mph, it slams into 4th and toys back and forth into 3rd-4th and then it goes back into limp dick mode. I took it all over, within a 100 mi radius to have the trans read and no body will read it because its too old. And I honestly can't afford to throw too much $ at it... 21 and paying for a house and 93 acres don't leave you with much money. Help??
does the od cancel button and light work? is the light currently on but appears dim?
edit oh nm it's flashing.post up the codes.sounds like mlps is going out.if you get code 67,start there.
