E4OD flashing OD light
Old Nov 25, 2015 | 06:24 PM
Tom Callan's Avatar
Tom Callan
I have a 1993 Ford F-350, E4OD, overdrive light just started flashing, shifts a little harder, but trying to find out what needs to be done to shut the flashing light off and return the vehicle back to it's normal self again, Thanks Tom.
Old Nov 25, 2015 | 06:34 PM
dixie460's Avatar
dixie460
Flashing OD light means there is one or more faults detected that will affect transmission operation. It's shifting hard because the control system is in fail-safe mode.
Read the fault codes from the computer, they will let you know what problem was detected and you can start looking for the cause of that.
Old Nov 25, 2015 | 08:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
HERE is how you can read the codes.
Old Nov 25, 2015 | 09:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
though much easier using a $15-35 obd1/eec-iv code reader.you get a hold function,audio beep and light to count.
someone once posted a vid using a multi meter to get the code.i was able to figure out which swings of the meter where "true" fluctuations and count 'em for him....but it wasn't pretty lol.
toss this in your toolbox;
Amazon.com: INNOVA 3145 Ford Digital Code Reader: Automotive Amazon.com: INNOVA 3145 Ford Digital Code Reader: Automotive
apparently this ones even more simple without a need to count beeps/flashes and just gives you the codes.
im old school lmao.i use this one;
http://www.ebay.com/itm/Actron-Ford-OBD-I-Diagnostic-Code-Flasher-CP9015-NIB-/151883878768?_trksid=p2141725.m3641.l6368
it's stupid simple to use too.it's not exactly hard to count some beeps.
for diesels don't forget to hold wide open throttle (key on.engine off of course.) then while holding wot,turn off hold on scanner.don't release throttle until scan is complete or you'll get false fipl/tps code-23.
Last edited by FORDF250HDXLT; Nov 25, 2015 at 10:10 PM. Reason: price adjustment.prices have dropped since i last viewed them
idi1993f350
16
May 12, 2017 08:33 AM
GulfcoastSD
Nov 12, 2013 01:14 PM
F350long
Oct 1, 2007 09:14 AM
HeyMoe
Jul 15, 2006 07:52 AM
nothingbutford
Feb 7, 2002 08:02 AM
