Return line issues
Old Mar 5, 2015 | 01:20 PM
90turbo's Avatar
90turbo
Return line issues
I have replaced my return lines after a leak and they keep popping off. I have them on super tight and i dont know if im building too much pressure somehow but i cant seem to figure out the issue any help?
Old Mar 5, 2015 | 04:26 PM
tecgod13's Avatar
tecgod13
What do you mean by popping off? Are the lines between the injectors coming off? or is this someplace else you're talking about.
There shouldn't be much pressure running through, but its possible the return line to the tank is blocked somewhere. You could try disconnecting the line at the rear of the engine that goes down to the tank and trying to blow through it. You should hear bubbles in the tank.
Old Mar 5, 2015 | 07:48 PM
90turbo's Avatar
90turbo
Yes the lines in between i have checked and there is no blockage but they pop off i also have where my tank switchover valve is stuck inbetween tanks so it wont turn on the electric pumps and i wish i could just bypass it without buying a new valve w/o spending money because i have none
Old Mar 6, 2015 | 01:29 PM
tecgod13's Avatar
tecgod13
Huh? There are no electric pumps on the diesel trucks. The selector valve is different than the gas models. On the diesel trucks it switches the sending and return lines as well as the fuel sender wiring. I believe on the gas ones it changers the fuel sender/pump wiring, and then the pump in the tank pressurizes the fuel which then pushes the valve over.
If your selector valve is stuck partway, the return line could be blocked there where it won't go to either tank, or be restricted enough it backs up and pops off.
Old Mar 7, 2015 | 04:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
correct. no electric pumps on a diesel unless one was added.
what do you mean by the selector is stuck between tanks? are you saying it is drawing from both tanks at the same time?
if this is the case, it is possible the return is blocked in the selector valve.
Old Mar 29, 2015 | 12:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
remove the lines from the selector valve and bypass it.simply hook up the rear tank (delivery and return) and keep the switch in the cab on the rear switch.now you'll have the fuel gauge reading correctly,no more issues with the return lines popping off because the fuel will return directly back into the rear tank without the blockage of the bad selector valve.won't cost ya anything if you've got some diesel rated hose laying around and you'll be good to go with just the rear tank.
Ol' Smokey
Mar 22, 2016 09:23 PM
Jonnys.1991
Apr 2, 2015 07:49 AM
77F-150
Feb 14, 2014 10:28 PM
tootall5764
Feb 18, 2011 09:13 PM
guitar333
Jul 10, 2004 09:14 AM
