Sponsored by: Real Truck
what is it?
Old Mar 12, 2015 | 05:28 PM
ugh3012's Avatar
ugh3012
What!? You are going about 80 MPH and you took picture? I guess not because your RPM is at zero.
Old Mar 12, 2015 | 07:03 PM
jasonw1976's Avatar
jasonw1976
Yeah and I took the pic from the passenger seat..... the rpms read zero because I'm doing 80 in reverse, goofy, sheeeesh!
Old Mar 13, 2015 | 02:26 AM
clem1226's Avatar
clem1226
Does the **** click through detents or is it a smooth sweep?
Old Mar 13, 2015 | 05:54 AM
jasonw1976's Avatar
jasonw1976
It's a smooth sweep from about 7 o'clock to about 5 o'clock.....
Old Mar 13, 2015 | 06:15 AM
MisterCMK's Avatar
MisterCMK
Did you try setting the brake and seeing if it will idle up with the switch?
Old Mar 13, 2015 | 07:29 AM
jasonw1976's Avatar
jasonw1976
I didn't specifically try to set the brake and play with it, but being a manual tranny I use the parking brake all the time and I fiddle with the **** from time to time and it doesn't seem to change the idle, but today when I go to lunch I will give it a try......
Old Mar 13, 2015 | 01:10 PM
droldsmorland's Avatar
droldsmorland
If its not OEM pull the panel and follow the wires if there is any. Could be something the PO put in it then removed when sold. Its not your instrument panel light fader is it?
Old Mar 17, 2015 | 08:13 AM
jasonw1976's Avatar
jasonw1976
Finally got around to trying the idle up theory, it's not that, I guess I'll have to stuff my big *** under the dash to see if it's hooked to anything and where it may lead to.......
Old Mar 17, 2015 | 10:50 AM
malodin's Avatar
malodin
looks like after market bass boost for an amp.
Old Mar 21, 2015 | 02:11 AM
clem1226's Avatar
clem1226
Ohhhhhhh
I remember those, I believe they were called "the epicenter "
Old Mar 21, 2015 | 06:05 AM
Just Strokin's Avatar
Just Strokin
That **** most likely adjust the brightness of the dash cluster lights. Some appears to have added the white gauge faces to your cluster. At night with lights on, try turning the ****.
sarpy
Sep 11, 2017 06:58 AM
bimmertrek
Oct 12, 2010 04:41 PM
old farmer
Sep 4, 2007 09:29 AM
medtech
Nov 4, 2005 11:28 AM
frustrated_2004
2004 - 2008 F150
Nov 29, 2003 05:21 PM
