I've got a little twist ****, about the size of the end of my pinky, on the right side of my steering wheel under my info, set up, reset buttons on my 06 F250 lariat and I don't know what it does, can anyone help me out, it doesn't seem to do anything noticeable....... Thanx!
There's a panel (at least on my '04) under the steering column. There's 4 or 6 ***** you turn 90 degrees to release the panel, so it will lower. The fuse panel is under that cover.
Nope and nope, the fuse panel access screws start a few inches below this ****, and the trip reset is the reset button right above the **** I'm asking about lol....... The **** I speak of makes almost a full turn and has a dot on it as a pointer......
Does it look factory? Some cheaper tune chips just use a **** to adjust between settings. Usually 6 adjustments. Does it feel like there are detents when turning? A picture would help.
I've got the cold speedo problem, it's fine once the temps start going up lol. As for the tuner thing, the PO did have a bully dog gt installed, that's still hooked up but no program on it, and he also gave me an SCT reflasher or something for it, I haven't really played with either of them yet...... So it could be something to do with them maybe, but what.......
