Dies when throttle falls
Old Mar 9, 2015 | 10:07 AM
mmfarms's Avatar
mmfarms
Trailering
My 7.3 has been sitting around for a year or so. I start it every now and then but don't drive it, as it isn't insured right now.
Recently I took it out and around the farm. I noticed when I let the throttle out the truck dies. If I ease it down it doesn't, but if you just let your foot off it does, like when shifting for example.
This was never an issue until I let it sit.
EDIT: I'm on an old account apparently. See Next post..
Old Mar 9, 2015 | 10:32 AM
deere55's Avatar
deere55
This is the same person.
The truck in question is the idi in my signature.
Sorry for any confusion.
EDIT: I just found this
https://www.ford-trucks.com/forums/1...d-problem.html
I'll try it. Shame on me for not looking first.
Old Mar 9, 2015 | 11:03 AM
Onus's Avatar
Onus
Funny that we are both having the same problem at nearly the same time!
Old Mar 9, 2015 | 11:09 AM
tecgod13's Avatar
tecgod13
I had the same problem with '93 that I picked up last year and barely drove. When I started driving it this fall it did the dieing after letting off the pedal.
I pulled the fuel filter and filled it with ATF, let it run 30 seconds, then shut it off and let it sit overnight. It wasn't any better the next day when I started it, so just shut it off and let it sit another day. The next morning started it up and it has been fine ever since.
Old Mar 9, 2015 | 11:59 AM
mf7lakes's Avatar
mf7lakes
i think its air in system. fuel drains out after a period of time after sitting for several weeks. when engine throttle is suddenly retarded, engine dies. after driving stop and go for several miles, all lines are full and symptoms go away. at least this is true with my 7.3.
Old Mar 9, 2015 | 12:20 PM
tecgod13's Avatar
tecgod13
Air intrusion is a different problem that surfaces immediately after starting the truck, it stalls and takes like 10 seconds to restart, then runs fine the rest of the day.
The issue at hand happens anytime the truck is running, you're driving down the road at normal speeds, take your foot of the gas pedal, hit the clutch, RPMs drop all the way down as the engine dies. If you lightly remove your foot and slowly bring the RPMs to idle everything is fine.
Old Mar 10, 2015 | 12:27 PM
deere55's Avatar
deere55
Let the atf sit over night and do its thing and runs fine now. Thanks
Old Mar 10, 2015 | 10:01 PM
bduemig's Avatar
bduemig
I think stale fuel gums up a valve in the IP. My truck sits in a garage all winter (South Dakota winters and 2wd puck ups don't go well together). I changed the IP and the next spring, when taking the truck out of storage, had the exact same issue. Rather than using atf, I used Diesel Clean. Worked fine ever since.
citka
Sep 30, 2017 08:50 AM
Nabors
34
Jul 17, 2013 03:48 PM
joshofalltrades
Mar 7, 2013 02:27 AM
LSO1123
Aug 25, 2011 10:47 AM
Hillbillyhotrod
Mar 30, 2010 11:12 AM
