Updated radius arm bushings
Old Mar 10, 2015 | 03:04 PM
dropitlow88's Avatar
dropitlow88
anybody try this? apparently the 2008 and up vans run a different style bushing for the radius arm than our beloved fords. thinking about a retrofit if the i beam dimensions are similar. seems like it could be a more durable setup. only down side would be that entire arm would need replaced. I am only contemplating because my current mounts are starting to disappear thoughts?
Old Mar 10, 2015 | 08:42 PM
dropitlow88
this is what i am referring to. good or bad idea?
Old Mar 10, 2015 | 08:47 PM
Chevy_Eater's Avatar
Chevy_Eater
They still use(d) the twin I beam that recently?
Old Mar 10, 2015 | 08:51 PM
dropitlow88
Yep. I work for a company that provides co. vehicles and I took a look under one of the newer fords. everything "looks" the same with the exception of that bushing. I think it was an E250? After that the ole' gears started turnin
Old Mar 10, 2015 | 11:53 PM
Ford_Six's Avatar
Ford_Six
They still use twin I beams under the 2wd F250 and F350.
Sent from my Brigadier using IB AutoGroup
miafcowboy
Oct 9, 2010 08:07 AM
BAJI26
Jun 23, 2009 06:52 AM
geowing
Oct 9, 2004 01:55 AM
ExcellentRed
Mar 1, 2004 09:06 PM
