GP going bad?
Old Mar 9, 2015 | 07:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
not really. if it will not start warm, but fires rite up after pouring room temp water over the pump i see no other way but to send it back.
or keep a couple gallons of water in the bed until you can lay the truck up for a while.
Old Mar 9, 2015 | 10:16 PM
Macrobb's Avatar
Macrobb
Check the junkyards for a spare pump. Chances are you can find a working one for $100 or so, and while it might not be the best, it will get you down the road while your other one is being worked on.
Old Mar 15, 2015 | 01:58 PM
jmuenchow's Avatar
jmuenchow
Just throwing this out there.. Could timing have any effect on this? I have not timed my pump dynamically
Old Mar 15, 2015 | 02:13 PM
tjc transport
i ain't rite
not that i have seen. if it starts, it should start and run whatever the timing is set at. it may not run good, but it should still start and run warm if it will start cold.
Old Mar 15, 2015 | 02:20 PM
jmuenchow's Avatar
jmuenchow
Okay. I figured. The truck started right up after sitting 24hrs..no hesitation whatsoever
Old Mar 15, 2015 | 02:31 PM
tjc transport
i ain't rite
unfortunately it sounds like the pump is heat soaking and causing your no warm start .
Old Mar 15, 2015 | 02:34 PM
jmuenchow's Avatar
jmuenchow
AKA bad pump right?
Old Mar 15, 2015 | 02:44 PM
tjc transport
i ain't rite
yup........
Torsten.H
34
Apr 1, 2017 09:14 AM
JohnSChisum
May 14, 2010 03:16 PM
fury9
Jan 10, 2010 06:47 PM
jo7.3idi
Dec 2, 2008 04:10 PM
Dave7.3
16
Oct 1, 2006 08:40 PM
