help please
Old Jul 23, 2003 | 02:13 PM
bronco--351W's Avatar
bronco--351W
help please
I have a quick question for you I have an '81 bronco 351w edelbrock intake and edelbrock carb. I am having the worse troubles trying to get it to idle right. I have to have the idle mixture screws out about 5 turns before it idle descent. and at that point it is at 1500rpms. I have the pcv and the carbon canister t'ed together and plug into the front of the carb then I have the brake booster plugged into the back into the intake. I sprayed some starting fluid around the carb and in the back of the carb when I spray it it revs up I jsut bought the edelbrock egr kits and have new gaskets for the carb. I called edelbrock and they said the heat riser that goes between the egr plate and the carb might be bad.. what are your thoughts?
Is it a dumb idea to use gasket sealer in a situation like this?
Old Jul 24, 2003 | 12:57 AM
Ford_Six's Avatar
Ford_Six
help please
I don't think the carbon canister should recieve full manifold vacuum constantly. According to the manual, the purge is controlled by ported vacuum, and is drawn into manifold vacuum. Try disconnecting and plugging the purge line near the manifold, and see if that helps.
Old Jul 24, 2003 | 10:02 AM
bronco--351W
help please
I dont have a purge valve is that bad?
Old Jul 25, 2003 | 01:17 PM
steve83's Avatar
steve83
help please
Not all engines got one. Check your vacuum map.
bronco--351W
Feb 21, 2010 10:45 PM
JWH2
Feb 22, 2008 06:40 PM
bronco--351W
1978 - 1996 Big Bronco
Aug 22, 2003 10:15 AM
bronco--351W
Jul 9, 2003 11:12 AM
