1978 - 1996 Big Bronco
help please
Old Jul 23, 2003 | 02:13 PM
bronco--351W's Avatar
bronco--351W
help please
I have a quick question for you I have an '81 bronco 351w edelbrock intake and edelbrock carb. I am having the worse troubles trying to get it to idle right. I have to have the idle mixture screws out about 5 turns before it idle descent. and at that point it is at 1500rpms. I have the pcv and the carbon canister t'ed together and plug into the front of the carb then I have the brake booster plugged into the back into the intake. I sprayed some starting fluid around the carb and in the back of the carb when I spray it it revs up I jsut bought the edelbrock egr kits and have new gaskets for the carb. I called edelbrock and they said the heat riser that goes between the egr plate and the carb might be bad.. what are your thoughts?
Old Jul 23, 2003 | 03:38 PM
Copper93's Avatar
Copper93
help please
You have a leak at the rear, probably the gasket. Try replacing the gasket underneath the carb and see if that helps out any. The spot where the starter fluid increased the rpm is where it is leaking. I don't think the heat riser would have anything to do with it but I could be wrong.
Old Jul 23, 2003 | 04:18 PM
bronco--351W
help please
There isnt a gasket between the heat riser and the carb edelbrock claims you do not need one
Old Jul 23, 2003 | 04:21 PM
GR8Diesel's Avatar
GR8Diesel
help please
I believe you need to have a gasket on both sides of the heat riser.
Old Aug 20, 2003 | 10:08 PM
go_spider's Avatar
go_spider
help please
Edelbrock may be right if you live in a perfect world, better safe than sorry. There might be a slight worp in one serface or another.
Old Aug 21, 2003 | 04:58 PM
89broncobob's Avatar
89broncobob
help please
I agree ,you need the gasket .thats prob were your leak is ..
Good luck ..
Old Aug 22, 2003 | 10:15 AM
DW2455's Avatar
DW2455
help please
me too, and your not gona get it to run right untill you fix the vac. leak. DW
bronco--351W
Feb 21, 2010 10:45 PM
arbuckles3
Dec 25, 2008 02:22 PM
bronco--351W
Jul 25, 2003 01:17 PM
bronco--351W
Jul 9, 2003 11:12 AM
