Low Fuel Light??
Old Feb 26, 2015 | 08:46 AM
motomax55's Avatar
motomax55
Low Fuel Light??
Hey Everyone,
I put 25 bucks worth of fuel in my truck yesterday, and after driving a mile away from the gas station, I got the low fuel light.
I did add some diesel additive to prevent gelling, would that have anything to do with it?
Old Feb 26, 2015 | 09:06 AM
KDAVID1's Avatar
KDAVID1
Mine has done that in the past (miles til empty didn't reset) after a fill up. It took a restart or two to catch up.
2006 F350 4X4
Old Feb 26, 2015 | 03:39 PM
dannyboy950's Avatar
dannyboy950
I have often found the float level switch sometimes sticks and then the float overcomes the reistance of the corrosion and begins registering correctly.
Old Feb 26, 2015 | 04:08 PM
Misky6.0's Avatar
Misky6.0
When stopping to put fuel in..
* Not shutting your engine off
* Only doing a partial fill-up
Seem to cause the fuel-level to be confused..
Thankfully, it usually corrects itself.
Old Feb 26, 2015 | 04:18 PM
Yahiko's Avatar
Yahiko
I read somewhere that it can take up to 30 minutes to
correct it you fill under those conditions.
It's the PCM not reacting to fuel sloshing on uneven surfaces
and speed changes.
Sean
Old Feb 26, 2015 | 08:28 PM
motomax55's Avatar
motomax55
Thanks for the reply guys.
The weird part was the truck was not running when I put gas in it. Drove it about 20 miles away and realized that I had forgotten to put in additive. I stopped, put it in, and also put in about 5 bucks of diesel just to mix it. The low fuel late came on about 20 minutes later a nearly half a tank.
I put in another 20 bucks today and the light went off. No idea.
Old Feb 26, 2015 | 09:04 PM
WatsonR's Avatar
WatsonR
Must have been the additive... what was it?
Old Feb 26, 2015 | 09:15 PM
motomax55's Avatar
motomax55
It was the Hot Shots
Old Feb 26, 2015 | 09:17 PM
WatsonR's Avatar
WatsonR
Now that's funny!
CdnSoldier
Jun 8, 2009 09:57 PM
mckeelandscaping
Dec 26, 2006 12:09 PM
ssnh
Oct 12, 2006 08:29 PM
hotrodmerc
Bronco II
21
Jan 14, 2005 08:58 AM
TJC1989
Dec 15, 2003 10:45 PM
