How far on LOW FUEL light?
Just wondering how far you guys can usually go after your low fuel light comes on. I have always been able to go at least 50miles after the light came on in my 2000 F-450 with 7.3PSD, but my 06 F-250 6' SC goes maybe 20 miles before it starts hesitating. Wasn't ready for that the first time. Jsut wondering if that is the norm on the new superdutys.
I usually go 20-30 miles after the light comes on... But when I gas up it usually only takes 24-25.5 gallons.. Considering it's a 29 gallon take I'd assume I have a bit more if I needed it. But that's also assuming the pickup is in the very bottom of the tank, which is may not be. I've driven to the point where the needle was on the low side of E, barely touching the line, and it still only took 26.? gallons. 5.4l '04 like my signature says.
-Jay
-Jay
I did once and only once. Went 11miles and filled up with 30gals. I fill to the filler neck. But everyone is right, don't run that low. When you run that low, your picking up any trash in the bottom of the tank. You'll either plug up you filters of worse your injectors. Doing this often, mean problem down the road. Also hard on the fuel pump.
With my old gas trucks that had duel tanks, I used to run the tank OUT before I switched and never had a problem with injectors or anything else. This was over more then 300,000 miles on my last truck.
On my PowerStroke I have done the same thing to empty the tanks for maint. but don't do it often. I still haven't had any problems with the fuel pumps or injectors.
