HELP! Key won't come out of the ignition
OK I am not sure what is happening here....... My truck was working fine no problem. Then I took it to run an errand I shut the truck off, and the key would not turn all the way to the off position so the key will come out. it turns off the engine but the key won't come out. I bought a new ignition switch with keys and same problem. I noticed before this happened that the key was getting hard to turn. Does anyone know what this is or (hopefully) how to fix it. Thanks for any help.
Not a 100 % sure on you issue. But the way I understand is you can turn the key all the way to the off position but the key will not come out? Since the key didn't come out you switch the key tumbler with new keys and still the key gets stuck in or is it hard to turn?
In the column there is a rod between the tumbler and ignitions switch. You may need to adjust your ignition switch position so that the tumbler rotates fully to off position. there are 2 nuts holding it in place.
Received 3,108 Likes
on
on
yes. there is a tab that works with the shifter interlock that breaks off. if that happens the key cylinder will think the truck is still in gear and will not let the key go to total off position so you can take it out.
Maybe ask in these forums https://www.ford-trucks.com/forums/forum30/ as they cover 1999 thru 2016 and the newer Ignition switches I think are different than the ones used on our IDI trucks.
on
63beater
04-18-2009 08:19 AM
