ignition key switch
Old Feb 27, 2007 | 03:49 PM
93Sunplex's Avatar
93Sunplex
ignition key switch
Im having a problem with my ignition. The key doesnt turn back to the off position. It just barely turns back far enough to not be in the on or run position. Luckily, its already messed up so that my key pulls out no matter what position its in, otherwise my key would be stuck in there. Is there a way to fix this or do i just need a new switch? If so, can the new switch be keyed to my current key so i dont have two keys?
Old Feb 27, 2007 | 04:16 PM
jle70's Avatar
jle70
The Key Lock Cylinder could be it, but I also have had to change a part in column. I think it is called ignition actuator. It is powder metal and does break.
Old Feb 27, 2007 | 06:17 PM
DOUBLEF222's Avatar
DOUBLEF222
I Just Replaced My Ing And Key It Broke When It Was Really Cold Out It Wouldnt Hardly Turn In Any Direction And Would Not Turn To Acc. At All. On Mine Under The Key Hole There In A Small Hole Where U Push The Small Nub Up To Pull The Key Ing. Out Gotta Have The Key To Do This. Pull Out The Old And Put In New. This Took All About 1 Hour Thats Includind Going To The Local Parts Store And Getting A New 1
