Boost fluctuation 5-10psi at 65mph?
Old Feb 21, 2015 | 08:06 AM
mfrank1296's Avatar
mfrank1296
While on the freeway using cruise control at 70mph my boost guage readings fluctuate between 5-10 pounds.Dont notice and issue with Rpms and drop in power just a difference in boost.Doesnt seem normal considering im at a constant speed.Suggestions? thanks guys
Old Feb 21, 2015 | 08:39 AM
white Buffalo's Avatar
white Buffalo
What type of gauge is it and where is the fitting plugged into to read the pressure?
Old Feb 21, 2015 | 08:41 AM
white Buffalo
Also , do you have a scanner or something like auto Enginuity to compare the MAP reading to the gauge reading?
Old Feb 21, 2015 | 10:10 AM
Tugly's Avatar
Tugly
Wind, hills... stuff like that. What are your RPMs?
Old Feb 21, 2015 | 10:28 AM
HD Rider's Avatar
HD Rider
Boost is an indication of engine load and not speed. Have you notice when parked (no load), regardless of RPM, you can't get boost? When cruising down the freeway, changes in wind, and grade will cause changes in boost. Boost will rise on even the slightest uphill grade and drop in the slightest down grade.
Old Feb 21, 2015 | 11:15 AM
The Brad's Avatar
The Brad
Also, cruise control is pretty **** about keeping speed exact. Is bet your boost is moving because the cruise says 64.9mph is too slow and 65.1 is too fast.
Old Feb 21, 2015 | 01:54 PM
white Buffalo
Is it a gradual needle movement or an erratic bouncing around type movement?
5-10 psi is a kinda big fluctuation.
Old Feb 22, 2015 | 10:59 PM
mfrank1296's Avatar
mfrank1296
no it's kinda slow...it will slowly good down and then slowly rise.Automete sport-comp II is the brand.
Old Feb 22, 2015 | 11:24 PM
clem1226's Avatar
clem1226
What is the outside air temp?
It could be the EBPV closing slightly to help the engine maintain operating temp.
Old Feb 22, 2015 | 11:29 PM
mfrank1296's Avatar
mfrank1296
ebpv was delted and Unplugged professionally.its winter in Michigan so anywhere from -25-30 now a days
Old Feb 23, 2015 | 06:58 AM
white Buffalo
My bad - I initialy took it as a bouncy erratic gauge needle. Maybe a video clip would be beneficial.
Old Feb 23, 2015 | 06:17 PM
clem1226's Avatar
clem1226
Is this truck new to you or is having a boost gauge new to you?
Just trying to get some context,it does not pay to leave any question unasked particularly on the Internet.
Old Feb 23, 2015 | 09:13 PM
whitetmw's Avatar
whitetmw
Boost Pressure Test
 Verify that MAP hose is not damaged, plugged or pinched
 Verify that intercooler hoses or intake are not leaking.
 Verify that the green Wastegate hose is not plugged.
 Monitor MGP (manifold gauge pressure) and RPM with the NGS Tester
 Road Test - select appropriate gear to obtain desired engine speed and full load on engine (best accomplished climbing hill or truck fully loaded).
 Spec: MGP 15 PSIG Min
Old Feb 24, 2015 | 07:41 AM
Tugly's Avatar
Tugly
Originally Posted by whitetmw
... Spec: MGP 15 PSIG Min
I should clarify. MGP min 15 PSI at WOT.
David Fehir
May 11, 2019 06:07 PM
Gatordog
17
Oct 21, 2015 07:54 AM
dieselsmoker
Apr 9, 2011 11:29 AM
stroke25
Mar 15, 2007 02:57 PM
Turf Truck
Feb 6, 2004 11:15 AM
