Press the Setup and Reset buttons and hold them, then turn the key to on, the gauges should do a full sweep and the display will say TEST. This might zero it. From there you can let go of the buttons and start the truck. Press Reset button to cycle through some interesting displays. Some are self explanatory and I don't know what the others mean.
Also, I've read the needle can actually back off the shaft and touch the lense, causing it to stick.
I thought I had heard somewhere in the grapevine that Ed was going to start working on these... just hasn't advertised it yet?
Will go check the status and reset button now. See what happens.
As I understand it he is working on other things.
Could be a frozen spider that was trying to get warm and you kicked her
out in the cole with the sweep test.
I once got a free hair cut because of the tiny spiders. Propane pool heater
that belched flame back at me do to some plugged nozzles on the gas burner.
So now I clean the nozzles if it's been off for any amount of time. Don't mind
the hair cut it's just the smell of burnt hair that sucks.
Anyway those tiny white spiders get into some places where you would think
that they would not be able to get to.
