We have a 2012 Ford Flex with remote start. Remote start doesn't seem to work when car is on an incline. Backed car into driveway and started but won't when pulled in. Is this common please help. Remote start is separate key fob.Remote start is factory.
Thanks
This is a WAG but it sounds like the sensor that determines if the hood is closed may think the hood is open when you pull in. Some have a switch but others have a device that senses the angle of the hood when opened. If you can find that hood sensor you may be able to adjust it so it still starts when pulled into the driveway.
Thanks
I'd have your dealership take a look, bigd1024. How many miles are on the Flex?
Like I said, just a guess. Hope it helps.
Leon
Thanks Leon I think that you might be right. I'll have them check it out.
45000 we bought it used a little over a month ago and carmax said it works fine. Obviously it doesn't.
Thanks for responding, bigd1024. I'd recommend making an appointment at your local Ford Dealership so they can check this out. To find a dealership near you, enter your ZIP code here: Locate a Dealer Search | Official Site of Ford Vehicles | Ford.com Once you have this diagnosed, I'll be able to research options to assist.
