Starting
Old Feb 3, 2013 | 12:30 PM
jack_pine's Avatar
jack_pine
Starting
So, this am I try to remote start the truck. It was 15 out and it sat overnight. I can see it flash, but it won't try to start. I tried this three times and gave up.
When I got in the truck a few minutes later, inserted key turned part way for glow plugs then when I turned the key to start the display wen blank and nothing happened, dead, no start. Tried this 3 times, same thing. On the fourth try it started up like normal. Started the rest of the day just fine.
Anybody ever experience anything like this?
Old Feb 3, 2013 | 02:48 PM
ruschejj's Avatar
ruschejj
I'm not saying this is your issue, but, the only time my remote start did not work was when the hood switch shorted out.
On the right side of the radiator, top corner, there is a switch that tells the PCM that the hood is shut. My switch went bad and it wouldn't remote start. I never had any key start problems though.
On edit, probably should put a trickle charger on the batts. They might be going bad.
Old Feb 3, 2013 | 04:12 PM
jack_pine's Avatar
jack_pine
I will check the switch. the rest of the day it remote started fine as with key. this truck only has 14k on it. My original thought when dead was batts... Don't think that is the issue....
Old Feb 3, 2013 | 05:52 PM
marchare011's Avatar
marchare011
If I recall correctly, there is something in the manual about only being allowed three attempts to remote start. After that, the system won't allow a remote start until an actual key start. I don't know why your truck responded to the remote start command, but failed to start tho.
Old Feb 3, 2013 | 06:15 PM
DTex250's Avatar
DTex250
mine did the same thing.. dealer swapped part after part trying to fix problem.
Three weeks later discovered loose wiring harness. All is good!
Old Feb 3, 2013 | 07:19 PM
jack_pine's Avatar
jack_pine
Me either....but the three and out thing makes some sense...will look it up.
thanks....
96_F250_Deezal
Feb 5, 2018 07:08 AM
SNIPER168308
Oct 1, 2011 06:37 PM
mauro12
Jul 21, 2011 09:17 PM
wannaBelkhuntin
Dec 11, 2010 02:02 AM
