Remote Start Problems
Old Feb 20, 2015 | 09:14 AM
bigd1024's Avatar
bigd1024
We have a 2012 Ford Flex with remote start. Remote start doesn't seem to work when car is on an incline. Backed car into driveway and started but won't when pulled in. Is this common please help. Remote start is separate key fob.Remote start is factory.
Thanks
Old Feb 20, 2015 | 09:39 AM
Leonandlisa's Avatar
Leonandlisa
This is a WAG but it sounds like the sensor that determines if the hood is closed may think the hood is open when you pull in. Some have a switch but others have a device that senses the angle of the hood when opened. If you can find that hood sensor you may be able to adjust it so it still starts when pulled into the driveway.
Like I said, just a guess. Hope it helps.
Leon
Old Feb 20, 2015 | 10:20 AM
FordService's Avatar
FordService
Official Ford Rep
Thanks
I'd have your dealership take a look, bigd1024. How many miles are on the Flex?
Crystal
Old Feb 20, 2015 | 08:09 PM
bigd1024's Avatar
bigd1024
45000 we bought it used a little over a month ago and carmax said it works fine. Obviously it doesn't.
Old Feb 20, 2015 | 08:10 PM
bigd1024's Avatar
bigd1024
Leon
Thanks Leon I think that you might be right. I'll have them check it out.
Old Feb 21, 2015 | 02:37 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
how much fuel is in it? if the fuel level is showing 1/4 or less it won't work. if your on an incline that can skew the reading and cause you issues.
Old Feb 23, 2015 | 10:29 AM
FordService
Official Ford Rep
Thanks for responding, bigd1024. I'd recommend making an appointment at your local Ford Dealership so they can check this out. To find a dealership near you, enter your ZIP code here: Locate a Dealer Search | Official Site of Ford Vehicles | Ford.com Once you have this diagnosed, I'll be able to research options to assist.
Crystal
Sketchz
Dec 15, 2023 12:58 PM
Soccer85
13
Nov 30, 2022 07:12 PM
dmorrill22
Oct 23, 2018 08:06 AM
96_F250_Deezal
Feb 5, 2018 07:08 AM
jack_pine
6.7L Power Stroke Diesel
Feb 3, 2013 07:19 PM
