Sponsored by: Auxito
door ajar
Old Jul 23, 2003 | 01:19 AM
joners's Avatar
joners
door ajar
Hey, at work the service truck door ajar stays on and same with lights, sometimes it flickers. quite a few trucks that i know do this, how do you fix it?
Old Jul 23, 2003 | 06:10 PM
QuickerPickerUpper's Avatar
QuickerPickerUpper
door ajar
My 97 did the same. Got it fixed under warranty. There is a micro switch close to the door mechinism, the way I understand it.
Old Jul 23, 2003 | 10:15 PM
NASCARTruckDude's Avatar
NASCARTruckDude
door ajar
I had the same problem with mine, but I read how to solve it on this site. Just spray the switch with some WD-40 and problem solved. No more Door Ajar.
Just don't use any type of grease to lubricate the switch, that's what messed it up in the first place.
Chris
Old Jul 23, 2003 | 11:00 PM
joners's Avatar
joners
door ajar
Where about's is the switch on the door jamb? heh
Old Jul 23, 2003 | 11:24 PM
NASCARTruckDude
door ajar
Get a can of some WD-40 and spray the door latch down good. It'll only take 5 seconds. Be sure your not spraying the hinge because the switch isn't in there.
Old Jul 23, 2003 | 11:30 PM
joners's Avatar
joners
door ajar
oh, so it's in the actual latch part of the door? im gonna go nuts with it tomorrow!!!
Old Jul 24, 2003 | 12:29 AM
Racerguy's Avatar
Racerguy
door ajar
Yup the switch is in the door latch. Spray LOTS of WD40 (only) into the latch and open and close the door a bunch of times. This will usually clean out the switch and it will work again.
cabldawg
May 31, 2022 05:08 PM
Adventure Rider
6.7L Power Stroke Diesel
Sep 8, 2012 01:57 PM
afonda
Jun 15, 2012 12:33 AM
ford9009
17
Mar 30, 2007 11:29 AM
cnoremac
1983 - 2012 Ranger & B-Series
Nov 13, 2002 10:06 PM
