door ajar beeper?
Old Mar 24, 2007 | 03:11 PM
ford9009's Avatar
ford9009
door ajar beeper?
How do i turn off/disconect, or what wire do i need to cut to turn off my door ajar beeper?
Old Mar 24, 2007 | 03:21 PM
McLeod's Avatar
McLeod
There is a chime or buzzer module (depending on model of truck) under dash right above throttle pedal area.
Take a look up there while the door is open and you won't miss it.
Simply remove the module.
Old Mar 24, 2007 | 03:25 PM
lostin90s's Avatar
lostin90s
Unplug wires and leave there. The next guy might like it.
Old Mar 27, 2007 | 08:21 AM
ford9009's Avatar
ford9009
thanks, found it
Old Mar 27, 2007 | 08:26 AM
Conanski's Avatar
Conanski
I think 99% of people disconnect those things.... they were particularly nasty buzz boxes some years.
Old Mar 27, 2007 | 08:28 AM
MustangGT221's Avatar
MustangGT221
My dad's 02 chevy is the worst I've ever heard.
Old Mar 27, 2007 | 08:34 AM
ford9009's Avatar
ford9009
well, it wouldnt have bothered me except for that it would beep any time the key is in and the door was open even when the truck was running, and it was annoying when i hd my doors opend listening to music while i was working
Old Mar 27, 2007 | 11:03 AM
ACarbone624's Avatar
ACarbone624
I disconnected mine...its was very annoying. Its pointless if it beeps all the time.
Old Mar 27, 2007 | 05:37 PM
mrl390's Avatar
mrl390
Mine was disconnected but I plugged it back in cause I had a nasty habit of leaving my lights on. Luckily it only dings when my lights are on and doors are opem, not just when my door is open.
Old Mar 27, 2007 | 06:19 PM
lostin90s's Avatar
lostin90s
I got one out of Lincoln town car because. Because I have a white truck and you will not believe how many time I get pull out in front of . So I run lights all time . I know it would be easier to wire them so come on when started but I like the key in ignition thing I have a bad habit of leaving them in. ( I don't lock it )
Old Mar 27, 2007 | 06:35 PM
rdz's Avatar
rdz
pulled the buzzer on my 99 cougar and woke up the next morning batt was dead turns out it pulling it tells the car the trunk is open. think the did this on purpose so you won't pull it out
Old Mar 27, 2007 | 08:15 PM
Jalon7's Avatar
Jalon7
I pulled mine and the next morning I had battery trouble. I have assumed it was coincidental but reading rdz's post makes me wonder. I have a '95 Eddie Bauer Ext. cab and I'm wondering if there might be somthing on it that made it pull the battery down. I was about to pull it again until I read rdz's post.
I wonder if it would be hard to figure out which particular wires on the plug go to the "door open" notification so we could leave the "lights on" notice intact.
Old Mar 27, 2007 | 08:26 PM
rdz's Avatar
rdz
at first i thought it was the pin switch but their wasn't one in the trunk. took me a couple days to figure it out first i pulled the bulb out but the indecater still said the trunk was open after i put the buzzer back in it was fixed i've pulled out lots before but this was the first to give me any trouble
Old Mar 28, 2007 | 07:16 PM
lostin90s's Avatar
lostin90s
I have pulled every one of mine at one time or other up to 95 with no problems.
Old Mar 28, 2007 | 07:28 PM
quicklook2's Avatar
quicklook2
i connected mine when i got the truck, i like that it reminds me when the keys are in the ignition.
