knocking sound
Old Feb 17, 2015 | 06:44 PM
bizzelj's Avatar
bizzelj
knocking sound
hey guys on my ford f250 i have a intermittent knocking sound when i turn the ac/ heater on any idea? it is not all the time and can never tell when it is going to happen. i always think the worse like it is a cylinder or something any idea
Old Feb 17, 2015 | 11:30 PM
Yahiko's Avatar
Yahiko
A/C compressor clutch snapping closed. It will make a good thunk.
Also you may think the A/C is not on. But any time defrost is on
So is the A/C compressor.
Sean
Old Feb 18, 2015 | 05:39 AM
bizzelj's Avatar
bizzelj
So that would make it thud a few times at start up every now and then?
Old Feb 18, 2015 | 03:44 PM
RideDiesel88's Avatar
RideDiesel88
A few times??? Mine only does it once after start up
Old Feb 18, 2015 | 05:04 PM
Yahiko's Avatar
Yahiko
Few times? I was reading tired when I replied last night.
Could be that it's getting ready to go if it's not holding
or also could be some other thing. Have someone start the truck
for you and stand at the passenger front corner with hood up.
The compressor is on that side and from underneath you can see
it. When the truck is started see if you can hear it in that location.
Then we will have a better idea on where it may be coming from.
Sean
Old Feb 18, 2015 | 05:48 PM
bizzelj's Avatar
bizzelj
It does it before I start too and a few times after I start so I'm not sure
Old Feb 18, 2015 | 06:09 PM
Yahiko's Avatar
Yahiko
The plot thickens…
Are you sure as to where it's coming from?
The A/C blend door can also make a thump.
Turn the A/C off start and see if the sound is there
or not. Then turn the truck off and let it sit for a 2 or 3
minutes. Try starting again. Any sound and from where?
If no sound then while it's running switch the A/C on.
Did you get ay thump?
Sean
Old Feb 18, 2015 | 06:13 PM
bizzelj's Avatar
bizzelj
Ok I've tried starting it without the a/c and it didn't do it. Started with the ac and it didn't do it it's really weird and it doesn't happen all the time.
Old Feb 18, 2015 | 07:39 PM
pickle40's Avatar
pickle40
If the sound is coming from the dash area.....it may be the vent damper door closing/opening. Check the vacuum pump located on the passenger side of the engine compartment next to the a/c blower. Check it for loose electrical connection and leaking vacuum hoses. My truck started doing this a while back after getting it back from the dealership. Found the electrical plug was not pushed in all the way. Plugged it in correctly and have not had any more issues.
Old Feb 19, 2015 | 03:05 PM
Tim C's Avatar
Tim C
If it sounds like a rapid fire tap, tap, tap, tap... Coming from the dash it may be a HVAC temp blend door actuator that's stripped out.
Pockets52
6.4L Power Stroke Diesel
Jul 12, 2014 12:59 PM
wulfman
Apr 10, 2012 04:31 PM
MisterRanger
1983 - 2012 Ranger & B-Series
20
Aug 23, 2011 06:56 AM
dewking
Apr 23, 2009 07:30 PM
Tom Hoffman
Jan 8, 2008 06:47 PM
